I was recently asked how much HP is my '66 289 is producing and I guessed somewhere around 250-275? (Ford's unmodified est is 225). Since some manufactures est can vary quite a bit, I just want to see what the forum's experts say (or anyone who feels like voicing there opinion). This post is just for fun and to see what components add what.
Here it is:
1966 289 A-code (rebuilt stock a few years ago - has good compression on all cylinders). If it's not mentioned below, it probably stock.
The modifications:
bottom end stock (except windage tray)
heads E6's ported (gasket matched) I and E with bowls and chambers cleaned up/smoothed to help with flow and shrouding issues. It looks like the previous owner installed 1.84" intake valves slightly trimmed down. (I know these heads are not the best, but I got them cheap...really cheap).
roller rockers - ratio 1.72
Edelbrock performer intake manifold - gasket matched.
1" 4-hole phenolic spacer
Road Demon 650 vacuum secondaries
Tri-y's with 2.25" mandrel bend exhaust, x-pipe, turbo mufflers (exhaust runs to rear of car)
Mallory electronic ignition with msd blaster 2 coil.
The idea of the mods was to make the car respond nice off idle (0-4800 rpms) and it seems to work. I do believe the carb and spacer is little much for the current setup (my old Holley 600 seems to respond better all around - waiting for rebuild).
Here it is:
The modifications:
