• Community Forums
  • Regional Forums and Event Information
Just Filled my nitrous bottle
  • Thread starter Thread starter Stangfreak95
  • Start date Start date Jul 28, 2004
Stangfreak95
add a 4
3,571
In your sister. If none, your mom
Jul 28, 2004
  • Jul 28, 2004
I filled the bottle yesterday. I got it at 7.5$/pound (+ taxes ) So I put the bottle back in place, did a quick "Pshhhh" to empty the line, as instructed to do. I hooked the line back in place, re-opened the valve, and I hear some "Pshhh" again.
I got a leak....Right in the back of my dash cluster, where one of my guages hooks up. A BIG 2 thumbs down
Gotta fix it now. ANd the stupid purge button is acting the wrong way. It'S always on,and when I PUSH on it, it stops purging. Needs to be the opposite way !
Oh well..
Stangfreak95
add a 4
3,571
Jul 28, 2004
  • Jul 28, 2004
UPDATE
The leak is from the hose in my car, for my inside gauge. The connections are fine, its BEFORE the connection where it leaks. Pissed..
mpcv2000
2,371
Montreal , Quebec !
Jul 29, 2004
  • Jul 29, 2004
That sucks !
I'm thinking about adding a guage for my Nitrous pressure but I'd like to get a electrical one !
Do they exist ?
I don't want to run a braided hose I rather just run electrical wires
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
Jul 29, 2004
  • Jul 29, 2004
That sucks man! But if you sniff the leak, at least you'll get a good laugh about it lol.
Strange about the purge button, switching the wires won't help - will it?
zoma
807
Ottawa, ON, Canada
Jul 29, 2004
  • Jul 29, 2004
Mario, it isn't that T connector I gave you, is it?
Stangfreak95
add a 4
3,571
Jul 29, 2004
  • Jul 29, 2004
No Jim the T connector is fine. It's that braided silver hose.
Stangfreak95
add a 4
3,571
Jul 29, 2004
  • Jul 29, 2004
Today I'm gonna try to switch the wires just to see but I'm pretty sure my wiring is good.
I'm also installing my Accufab AFPR. I have the upper intake off for that. I found out what my fuel pressure was. I'm running 29psi at idle vacuum on, and 37psi vacuum off, on the stock regulator. Thats low IMO for my mods. I dont wanna run lean on the juice so Ill raise it a little.
Stangfreak95
add a 4
3,571
Jul 29, 2004
  • Jul 29, 2004
mpcv2000 said:
That sucks !
Do they exist ?
They exist fore sure. I beleive more in a mechanical gauge though. Its a PITA to make it fit there but It shouold be worthed.
SpencB
388
Ontario, Canada
Jul 29, 2004
  • Jul 29, 2004
I have a Nitrous Express ( Auto Meter) gauge in 1FUN TOY. Have yet to try it as we're not wasting time running the car this year to keep the motor fresh for resale. Next year we'll deal with all that.
Good Luck Mario.. you'll get er all fix'd up I'm sure.
Stangfreak95
add a 4
3,571
Aug 2, 2004
#10
  • Aug 2, 2004
  • #10
I finally fixed that purge button. The problem was the switch itself, not the wiring. The new purge button is a little bigger so I had to drill a bigger hole. While doing that in the car, with all other switches plugged in, I ended up breaking one other switch by twisting it. But now everything is fine. Everything works so fa and I'll most likely be tring it today. I had to bypass the leaking hose so I wwont be running the interior gauge for the moment. Just gotta make another "tune" for the nitrous.
Vacuum line question?
  • Mustang Momma
  • Feb 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 3, 2026
My stinky friction modifier story
  • nicholase
  • Jan 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 6, 2025
BlakeusMaximus
M
  • mnky99
  • Sep 5, 2025
mnky99
M
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
  • Community Forums
