Just got battery relocation kit... Anything I should know?
GTA_V6_Mustang
1,326
Miami, FL
Well pretty much that. I know the positive cable thats like 16ft, lol goes to the starter, but where I am kinda confused is what do I do with the alternator cable to charge the battery. Instructions are not very clear. ANyone ever install the 555-3800 steeda relocate kit?
i built my own kit but the idea is still the same.
i ran the positive to the main lug on the fuse box. alot easier.
negative i grounded to the quad shock bracket. I also upgraded the engine ground
does the kit come with a cut off switch? if it doesnt, the alt wire would be pointless because the car would still run.
for the alternator you got to run the cable back to the (battery between the switch and battery) instead of the fuse box.
i still havent ran the alternator cable yet.
where do you plan on installing the cut off switch?
good luck
