Just installed a remanufactured 3g alt off of ebay. I read all the how to's, and installed it with 4 gauge cable, orange wires unconnected, 175 amp fuse inline on the 4ga cable. My question is this:
Voltage across the battery terminals at start up exceeds 14 volts. But after a short jaunt around the block with all the accessories running, the voltage pegs at 13.90ish volts. It doesn't matter if I goose the engine, keep it steady at 2000rpm, etc. I have the general understanding that the voltage is ultimately determined by the alternator regulator, so is it OK that the voltage is so low? I have read a bunch of posts and web pages calling for 14+ volts at higher revs, but I have yet to find a good answer that satisfies me. Also, the 3g has the larger pulley on it, but once again, would that really matter? I am somewhat comforted with the fact that since the voltage is staying well above 13v with all accessories on-ac on high/lights on/hazards flashing/etc, the alternator is able to put out the amps needed to keep the battery charged (I assume). SO, does anyone opinion on the minimum voltage the alt should be putting out? Is the regulator on its way out? Or am I just fretting over nothing?
Thanks in advance.
Thanks in advance.
