just installed 4:10's and cant get any traction at the track!!!!!!
superslothguy
103
ok so last night i was trying so hard to get my times down
i went from 2:73s to 4:10s in my 89 5speed and i cant figure out why i cant get traction when i only have 10 pounds of air in my mickey tompson drag raidals when im launching at 2k
my current mods are pulleys, fell exg., cai, and new 4:10s
by the way my drag raidals are getting down there tread wise should i get new ones and try it?
:shrug: :shrug: :shrug: :shrug: :shrug: :shrug: :shrug: :shrug:
Is it hot there? How was the track prepped? Plenty of VHT? I couldn't hook for the life of me last Sunday and I run 3.55's with 275/50 BFG DR's. The outside temp was 97 degree, which made the track like butter. Also, stock suspension + 4.10's = spinnnnnnn.
This may be why:
Stock peak torque: 300 lb/ft
Stock gear: 2.73:1
Stock 1st gear: 3.35:1
300 x (2.73 x 3.35) = 2743 lb/ft of torque to rear tires
Now put 4.10:1 gears into the equation:
300 x (4.10 x 3.35) = 4120 lb/ft of torque to rear tires
You've nearly doubled the torque to the rear tires!
hrspwrjunkie said:
This may be why:
Stock gear: 2.73:1
Right on! Just like they say on TV - It's all Numb3rs...
Suspension mods......? I got the same promblem man. :bang: But they are fun.
I think if I invest into some lower control arms, and adjustable shocks it might help but really dont know.
I heard once you can get your 4.10's to hook it will "feel" like a 100HP gain.
If you can't find a good RPM to dump the clutch from, you can start your runs from 1000 - 1500 RPM's. Sure you'll bog, but you can always move the RPM's up until you hit your spot where you won't spin but you won't bog either....
