Just installed control arms... Quick Question.
  • Thread starter Thread starter 90lxcoupe
  • Start date Start date Nov 5, 2005
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Nov 5, 2005
  • Nov 5, 2005
i just put my edelbrock adjustable uppers and MM weight jackers on yesterday and when i put the car back on the ground it seems like it moved the tire forward quite a bit. has this happened to anyone else, should i be worried about this??
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Nov 5, 2005
  • Nov 5, 2005
bump
strokedandblown
Banned
May 3, 2005
555
USA
Nov 5, 2005
  • Nov 5, 2005
how much did it move the tire forward?
does it drive normal or is it all messed up
Blk91stang
607
North Brunswick, NJ
Nov 5, 2005
  • Nov 5, 2005
are the lowers adjustable? If so, adjust them to so their centered and square with the rest of the car. If their not adjustable, live with it or get new control arms.
F
FiveOfastback
32
Bethlehem, pa
Nov 5, 2005
  • Nov 5, 2005
DI you have weight on the axle when you torqed the control arm bolts? You may have bound up the bushings. Loosen the lowers slightly with weight on the axle (jack stands under axle) Bounce the suspension slightly the retorq with weight still on car. Just my .02$
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Nov 6, 2005
  • Nov 6, 2005
the only thing that is adjustable is the spring perch, and i didnt torque the bolts yet i was going to do that all at once when it was done then i noticed the rear axle seemed further up then it was before so i put the tires on the car and put it on the ground... i havent driven the car yet
it didnt look as bad when it was on the ground when i had weight on the tires.
C
Suspension Rear suspension help
  • Clark302
  • Aug 17, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
Clark302
C
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
Tightening upper control arm bushings at ride height dilemma… need some help
  • AnthonyA1234
  • Dec 27, 2024
  • 2 3
7K
Fox 5.0 Mustang Tech Feb 27, 2025
General karthief
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
