i just put my edelbrock adjustable uppers and MM weight jackers on yesterday and when i put the car back on the ground it seems like it moved the tire forward quite a bit. has this happened to anyone else, should i be worried about this??
are the lowers adjustable? If so, adjust them to so their centered and square with the rest of the car. If their not adjustable, live with it or get new control arms.
DI you have weight on the axle when you torqed the control arm bolts? You may have bound up the bushings. Loosen the lowers slightly with weight on the axle (jack stands under axle) Bounce the suspension slightly the retorq with weight still on car. Just my .02$
the only thing that is adjustable is the spring perch, and i didnt torque the bolts yet i was going to do that all at once when it was done then i noticed the rear axle seemed further up then it was before so i put the tires on the car and put it on the ground... i havent driven the car yet
it didnt look as bad when it was on the ground when i had weight on the tires.
