Just installed mgw shifter: problem
nonglossjason
I did not have intercourse with a sheep.
Jan 27, 2006
138
20
39
Ok i just installed the mgw shifter and did everything right installing wise. Even checked the stops twice but when im cruising in 5th gear its vibrates its way out of gear. In all gears it has a little play up and down and when i barely push up it feels like its going to go into nuetral. But in 5th after about 5 min, it pops into neutral. Never did this with the stock shifter. What can i do to fix this? Thanks guys
I dont have that shifter but the obvious test (to me) would be:
Back the stop for 1,3,5 out a little bit and test drive it. Dont be banging 1.3,5 since you dont have a functional stop anymore. If it still pops out, you know the shifter stop isnt the issue.
If the issue goes away, you might need to dial in the stop a little more closely or fine tune it a couple times.
Good luck.
Well if the shifter stops arnt properly adjusted it could mess up my tranny (what the install book said) so therefore i am hesitant to back it off and dive it. BUMP
I have the mgw on a T-5z. I don't know how you set the stops, but the directions are to put it in each gear; tighten the stop until it reaches the shift lever; then back it off one full turn. I haven't looked at the directions in weeks so check the manual on that one. If they are too close it can cause the transmission to pop out of gear like that.
Who is to say your stops are adjusted properly right now? Having the stops adjusted too tightly can damage the trans too.
If you read my post, you'd see that I said not to bang gears (shift into gears as hard and fast as you can) after you ran the adjuster out. You are only doing this adjustment for diagnostics; if the shifter pops out of 5th with the adjuster run outwards, the stops arent the issue.
The stock shifter has no stops. So if you were you able to use a stock shifter without damaging the transmission, you should be able to drive with the stops backed out on the new shifter.
Good luck.
