Just Replaced head gaskets but now have trouble starting car.....any ideas?
I just did a head gasket change for the first time and just hooked everything back up. My mods are listed in my signiture. Now when I try to start it, the engine turns over and sounds like it wants to go, but it doesnt fire up. Any ideas as to what could possibly be causing this? Could it be that I need to tighten the rocker arms more or something like that? Possible distributor issue? Any help would be great. Thanks
I labeled all the ignition wires and put them back in the same location. I even bought brand new spark plugs. As for the muffler bearing, i have no idea what that is. I dont think I did anything with it either. Any more ideas as to what it could be?
lol those dumb muffler bearings struck again. they musta shimmied themselves about 1/100th of an inch out of its seat. i can guaruntee thats the problem. that little bit can cause all kinds of damage! take it from me. i have witnessed their destruction.
you have never been asked to check your muffler bearings? well now you can pull the trick on your friends.... take them for a ride. say you hear something weird..pull off the road and ask them wiggle the exhaust to see if the muffler bearings are bad... and laugh at them when they say they are ok, or cant find them and keep laughing cause they just burnt their hands for being a dumbass!....just think of it this way if a muffler has no moving parts... why does it need a bearing? its apart of automotive ideology going back past my fathers time. (hes almost 60)... so this is a trick thats handed down from generation to generation.
agent007kimball said:
I thinkk it may be the distributor. I thought I put it back correctly, but if not, what is the correct way to put it back then?
set cylinder #1 to 10* BTDC, then place the dizzy with the rotor pointing straght back... or as close to #1 on the cap as possible....
you can have the distributor pointed anyway you want just as long as the plug wires are in the right spots...
And incase you're unsure how to do that, pull the #1 spark plug and hold your thumb over the hole, have a friend bump the key over a few times, with the car in park/neutral an parking break set. When it blows your thumb off the hole its almost at the top. Then just put a socket on the nut for the balancer and align the tab w/ 0 on the balancer.
For real... no jokes here...
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) Coil
B.) TFI module
C.) PIP sensor in distributor
D.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
E.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires
F.) Ignition switch - look for 12 volts at the fuel injector red wires
G.) Computer
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
If it starts then, you have a fuel management issue. Continue the checklist with emphasis of fuel related items that follow. If it doesn’t ,then it is a computer or timing issue: see Step 4.
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing. A Noid light available from Autozone, is one way to test the injector wiring. I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
A.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
B.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
C.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off only likely if the engine has been worked on recently).
