just wondering about bbk shorties
i've had my origional gaskets on for a year. no leaks. driver side in from the bottom and you may need to disconnect the steering shaft. pass. side from the top and you'll neet to remove the intake tube/maf/ airbox. this info is for unequal shorties BTW
get a decent set of header bolts.... :nice:
the front bolt on the drivers side of the power steering pump can be a bitch... IIRC you can use a 1/4 drive with a universal in order to get it out... i took out the battery so i had some more room as well..
thanks for the replies
I got them on the other night. BBK equal length shorties = unhook steering shaft on driver side and pass through bottom to the top. Passenger side = unbolt motormount from subframe and lift motor 2-3 inches and take off the smog pump b.s.:bs:
took about 4 hours of install and another 4 trying to get the xpipe to seal up at the header lol im a 2.3 turbo guy so i dont play with the 5.0's as much:scratch: but i do know my way around:rock: lol thanks for the replies
