From my research I have found out a lot of the info I will need to pick the right balancer, but I just want to double check if I have it correct and some more questions too. The top two balancers are Romac and Pioneer/powerbond. The pioneer is more in my price range. The balancer should be a 50oz piece, SFI approved is a big plus, and be the 4 bolt. Is elastometer the best construction? All that I have seen have timing marks that only go up to 10 BTDC, are there other models that go higher? Will I need a spacer? Did you have to put a coat of clear on yours to keep it from rusting? part numbers would be awsome.
Thanks
Thanks
