KB 9# w/stock gears?
It's actually still tough to keep from spinning through a launch. Stock gears work fine. The only reason I would ever switch is if I installed a T-56 and started running sticky tires at the track.
Stock gears would be fine, lots of top end though. I have 3:55's now and will probably do 3:73's. I think if you go any higher you will be hitting the rev limiter alot in the lower gears, unless you get really good at shifting with the 3650.
AmBo said:
What would it be like? I think just about everyone here with a 9# kit run 3.73 or 4.10. I wonder what it would be like on stock gears? :cheers:
I've got stock gears. It gets the job done. You can spinn the tires at will. For a DD I would keep the stock gears, but I am going to see some track action so I am buying stickies and I will put in 3.73's when I rebuild the rear end.
