Hey guys, going to get a KB blower shortly. I've been reading posts to see how people like them. I am set on the off idle boost as I'm building a street/some strip car. KB's website shows 2 kits: the TS 1000 kit and the TB 1000-BK kit.
From what I can see the TS 1000 kit is the basic 6 psi kit with an FMU and no bypass, designed to run with everything stock including injectors. The TB 1000 kit shows 8-18 psi with a bypass and no FMU.
I plan on running 8 psi and like the idea of a bypass valve to limit heat at low rpm. I plan on installing a PRO M 77mm MAF matched to 42# injectors, Walbro 255 LPH HP fuel pump and Holley AFPR. I will get a tune after install (already have an SCT 4 bank chip installed, could tune to that?) Don't think you need the FMU with the above parts added.
Will this kit pass emissions after changing injectors, pump etc;? or are you limited to the basic 6 psi kit?
Their website is kinda confusing between the two kits.
Any thoughts are appreciated.
