- Sep 3, 2007
- 1
- 0
- 0
hello could any body help me? i just had my car at the dyno and i am making 385 hp at the wheels , and over 400 ft lbs torque.. now i have afr 165 with the e cam and ford motorsport 1.6 roller rockers with a walbro 255 fuel pump. o this is with a 12 pound pullie.. i just went to a 8 lb cuz the car sounds better with it.. i think the 12 is to much.. i just found a bunch of oil behinde the motor coming out the pcv... i read were you want to ahhhhhh use a one way check valve !! so you dont preshure rize the engine?? any sugjestions?? i am just disopointed this blower does not make nois... i was told it does.. how do i no if it is a true 2.2.. it does have the bypass tube coming around it.. if you could help email [email protected] thanks
