Kenny Brown subframe connectors
Acidpete said:
I believe that's correct Brian. In all honesty if you already have subs you should be able to simply weld a 3/4" square tube up and have jacking rails, that's all it is. However, if you're going to get subs and get them from KB you might as well add the rails.
i've heard that if you get the full kit (SFC, Matrix, Jacking R.) they'll get in the way of aftermarket rear components such as the panhard bar, torque box, etc.. is this true?
I don't' see how if would get in the way of the suspension, If you get the whole kit side exhaust won't fit though.
