Key Chime
onefstsnake
792
Northern VA
Well I had to pull the cluster out to replace a couple bulbs... :bang:
And I think the key chime broke off. Its a small white plastic piece with one wire going to it and two metal strips that when touched together sound the key chime.
I cant find out where its mounted to. Right now its just hanging.
Also I found a small one wire connector (same small connector used in scanning codes under hood). I cant find a spade terminal it connects to. Is it just an extra?
Everything seems to work fine without it.
