Key wont come out in 72
Hi v8xploder I ran into the same problem on a chums 73 mustang.......it turned out to be the collar just below the steering wheel had turned slightly (on the steering column itself) not allowing key rod to return and let ignition turn back to off position collar set screws came loose over time.................something to look at anyway ..............I hope this helps you out
