keyless entry
  • Thread starter Thread starter jrod92
  • Start date Start date Jan 11, 2006
J
jrod92
66
  • Jan 11, 2006
i bought an audiovox keyless entry system for my car, has anyone installed one of these or any keyless entry and can give me some pointers/tips? thanks
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Jan 11, 2006
  • Jan 11, 2006
if you can, solder and heat shrink the wires. It will save headaches in the future. If there isn't room to solder, use some butt connectors and crimp them tightly and then use electrical tape to tape up all the crimped wires. This will help too:
1992-93 Ford Mustang Security Information
Constant 12V+ Yellow Ignition Switch Harness
Starter White/Pink or Red/Blue Ignition Switch Harness
Ignition Red/Light Green Ignition Switch Harness
Accessory Gray/Yellow Ignition Switch Harness
Tach Tan/Yellow Coil
Neutral Safety Wire Not Grounding OEM Switch opens Starter Circuit
Brake Switch Red/Green Brake Switch
Trunk Release Purple/Yellow (+) Switch
Trunk Pin n/a Works with Dome Light
Parking Lights Brown (+) Light Switch or Driver's Kick Panel
Head Lamp Red/Yellow (+) Light Switch
Hood Pin n/a
Factory Disarm n/a
Door Trigger Black/Blue (+) Pin Switch or Courtesy Light
Door Lock Pink/Yellow Driver's Kick Panel
Door Unlock Pink/Green Reverse Polarity
Horn Wire Yellow/Light Green (-) Steering Column
Windows Up LF=White/Black, RF=White/Yellow, LR=Yellow/Blue, RR=Yellow/Blue
Windows Down LF=Yellow, RF=Tan/Blue, LR=Gray/Orange, RR=Red/Black
HISSIN50
34
129
Jan 11, 2006
  • Jan 11, 2006
What parts do you need help with?
Does it have on-board relays?
For the trunk popper, it is easiest IMHO to just grab the output at the switch in the glovebox.
For locks, the harnesses are at the top of the driver side kick panel. The primary color is pink on most all the lock wires you use.
Post more specific questions and we can help more.
Good luck.
glowstang93
20+ Year Stangneter
Feb 9, 2003
853
Illinois
Jan 12, 2006
  • Jan 12, 2006
Call the 800 #, if its the same one i bought, they told me I needed a relay for the doors, and one for the hatch and on and on. The cheap $60 keyless entry was then reaching into th $100 range and a pita. I spent $200, went to Circuit City, had them install a Python keyless entry alarm system and the pita stuff was theirs to do.
J
jrod92
66
  • Jan 16, 2006
just need help in general the instructrions seem quite overwhelming. any suggestions would be helpful. what type of factory door lock system is it to begin with a 3 wire ground swtiched signal, 3 wire ground switched 2 step, 3 wire positive switched or 3 wire switched 2 step?
HISSIN50
34
129
Jan 16, 2006
  • Jan 16, 2006
Seems to me that we use reverse polarity locks, unless your car had factory keyless.
old_blue
1,783
282
124
Jan 16, 2006
  • Jan 16, 2006
Hood Pin n/a
Factory Disarm n/a
what color is the dome light and where would be the best location to get at it? also where would be the best place to get at the starter wires? I am guess in the steering column? not trying to steal this thread, I just never finished hooking mine up and these are the only 2 things I had left to do.
HISSIN50
34
129
Jan 16, 2006
  • Jan 16, 2006
Cant help with the dome light (I dont have one so I never hooked it up).
The crank wire (just one) should be easily accessible in the steering column (at the ignition switch or in the harness in that parallels the steering shaft).
Good luck.
old_blue
1,783
282
124
Jan 16, 2006
  • Jan 16, 2006
sweet thanks.
Forced Induction V3 pulley change
  • JD1964
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 21, 2025
JD1964
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
R
Electrical 1987 Map Light
  • Riley Barth
  • May 30, 2026
Fox 5.0 Mustang Tech Jul 6, 2026
Riley Barth
R
Foxbody Keyless Entry Help
  • sawan
  • Apr 2, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 2, 2024
AeroCoupe
Forced Induction Vortech v3 low boost (like 2 psi)
  • 92Rustang
  • Jul 29, 2024
3K
Fox 5.0 Mustang Tech Oct 2, 2025
Mindseye007
