Kill Switch
  • Thread starter Thread starter Pbum5
  • Start date Start date May 22, 2005
Pbum5
515
Minneapolis, MN
May 22, 2005
  • May 22, 2005
Hey all,
I am going to hook up a kill switch to the unused neutral safety switch.
I plan on using a toggle switch and mounting in a hidden spot.
My question is what toggle switch to get.
15 or 20 AMP??
Or a different one?
Thanks.
danewers
97
  • May 23, 2005
i was thinking of doing the same thing. sorry im not sure what kind of switch you would want to use. but wouldnt you still be able to hot-wire the car at the solenoid?
Pbum5
515
Minneapolis, MN
May 23, 2005
  • May 23, 2005
Good question. anyone have an answer?
cardude
221
Portland, OR
May 23, 2005
  • May 23, 2005
*cough I did it *cough and used a 20A and it works great! very hidden and no one knows where it is because I can flick it with a standard move of my hand doing something else that you normally do when starting a car.... i will let you chew on that for a while
stangbuilder66
25
  • May 23, 2005
So you put it over by the seatbelt too?
geostang351
946
Danb., CT
May 23, 2005
  • May 23, 2005
How bout just under or to the side of the ignition itself, so you can turn the key and swipe the toggle in one motion. Not a long bulky toggle but a short low profile one.
steel1212
1,180
Frankfort, Ky
May 23, 2005
  • May 23, 2005
How about rewireing the cigarette lighter to kill or activate? Push in for on pull out for off?
XXBULLETSXX
301
Kannapolis, NC
May 24, 2005
  • May 24, 2005
Sweet idea! If someone figures out how to do that let me know!
iskwezm
4,159
20
79
Rowland Heights,California
May 24, 2005
  • May 24, 2005
all you do is take apart the back of the socket,drill for a small switch and use the push in element to activate it.
cardude
221
Portland, OR
May 25, 2005
#10
  • May 25, 2005
  • #10
i put it on my ebrake bracket (you cant even see it unless you know its there) and before i start the car I release the brake and when I stop I set the brake. only thing you hear is a click.
10secgoal
2,801
San Diego
May 25, 2005
#11
  • May 25, 2005
  • #11
If you have an MSD box.....you can't hot wire. there are two types of ignition switch's on an MSD. If you take the one you don't use, and ground it out, the box won't turn on. That is a good kill switch. To acutally hot witre it, you'd have to know about it, and cut the wire or find it, then hot wire it.
R
ron67fb
1,117
SF Bay area, CA
May 25, 2005
#12
  • May 25, 2005
  • #12
Yes, the lockout only prevents the starter from turning over, otherwise your car would die when you put it in gear. Since part of hotwiring at the solenoid is to crank the starter, that particular kill switch won't prevent the car from starting. One of the best circuits for a switch is the wire leading to your distributor.
Edbert
3,548
32
109
Austin TX
May 25, 2005
#13
  • May 25, 2005
  • #13
Didn't you buy a Painless Perfomance kit? If so just use that 50amp "maxi-fuse", if you locate it correctly there's no currrent that can get anywhere near your starter or ignition, so a hot-wire is out of the question.
When I read "kill switch" I thought you meant the one required by dragstrip sanctioning bodies.
Pbum5
515
Minneapolis, MN
May 25, 2005
#14
  • May 25, 2005
  • #14
Nope, Don’t have the painless kit and it’s not for a racing type application.
Someone mentioned a kill switch for security purposes in another thread.
So I was wondering about that.
But it sounds like a person can still hotwire it at the solenoid.
Edbert
3,548
32
109
Austin TX
May 26, 2005
#15
  • May 26, 2005
  • #15
IMO, the best place for a security related (anti-theft) electrical device would be between the battery + and the fuse box. That will disable just about everything, most important of which is the ignition. They can still crank the starter but she wont fire. If you go that route consider using a giant fuse instead of a switch, then you get another kind of security, the one from electrical fire.
If you fear your car being stolen, please realize that they'll most likely tow it away with a flatbed anyhow.
latamud
791
Tampa, FL
May 27, 2005
#16
  • May 27, 2005
  • #16
You could rig the dimmer switch(on the floor) to kill the car, or power the electric fuel pump etc. The cigarette lighter, you could probably rig it to be a push start buttom for the car?
Pbum5
515
Minneapolis, MN
May 27, 2005
#17
  • May 27, 2005
  • #17
yeah,
I know if someone wants it bad enough they can get it, or tow it.
I was just looking at a simple kill that might stop the not so smart thief.
SJB Parasitic Draw, Fuse 59&67
  • 2005 Mustang V6
  • Apr 30, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 29, 2026
boatillo
Radio, Speaker Upgrades
  • TripleYellow
  • Apr 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 24, 2026
TripleYellow
E
Terminator X Kill Switch install
  • Ethereal_Zer0
  • Feb 8, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 11, 2025
90sickfox
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Electrical 1986 Mustang GT Multifunction Switch Question
  • Willybill32
  • Oct 26, 2025
Fox 5.0 Mustang Tech Nov 22, 2025
Willybill32
