king cobra clutch
  • Thread starter Thread starter 5.0fox
  • Start date Start date Dec 8, 2004
5.0fox
410
buckley/enumclaw wa
Dec 8, 2004
  • Dec 8, 2004
i just ordered a king cobra clutch and was wondering if you guys can tell me all about it.
thx in advance
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Dec 8, 2004
  • Dec 8, 2004
I have the King Cobra clutch...I like it a lot and it holds my power 95% of the time...and the pedal feel is heavy to a "regular" car...but light to me...you can slip it pretty easily to...it isn't like an on/off switch...
I bet you will like it...
Funanin
356
Horsham, Pennsylvania
Dec 9, 2004
  • Dec 9, 2004
yea its a good clutch for the money and for the holding power. Obviously if u beat on it they dont last more than about a year (im on my 3rd one) Like dropping it at 5 grand while u are already moving in 2nd to get it to turn sideways in traffic. At the track it holds good too, i would say 50% more holding power than stock.
bmorrisj
449
Buena Park, CA
Dec 9, 2004
  • Dec 9, 2004
how about mixing a KC pressure plate, with a centerforce or spec disc....
Funanin
356
Dec 9, 2004
  • Dec 9, 2004
probably wouldnt have the same holding power as the centerforce or spec because the pressure plate is not as strong
MisterCMK
20+ Year Stangneter
Oct 2, 2004
201
Fargo, ND
Dec 9, 2004
  • Dec 9, 2004
i too would like to know, since I think with 126k on my original clutch, I am due for a new one.
bmorrisj
449
Buena Park, CA
Dec 9, 2004
  • Dec 9, 2004
oh yea my clutch is on its way out, i wish i had the money to change it when i replaced the tranny, being stuck with only 4th gear was not good for it at all....
runningmole
1,127
San Diego, CA
Dec 9, 2004
  • Dec 9, 2004
It's holding up fine to my 351rwtq
5.0 Nostalgia
904
CT
Dec 9, 2004
  • Dec 9, 2004
For the money, it's a good clutch. It will not chirp gears as easy as other clutches, but it will hold.
jpctln
198
StL, MO
Dec 9, 2004
#10
  • Dec 9, 2004
  • #10
Mine still chatters a little bit when engaging 1st gear. I'm used to it now, and it's definately not anything unbearable.
HISSIN50
34
129
Dec 9, 2004
#11
  • Dec 9, 2004
  • #11
does it use an organic disk? anyone have a comparison with it vs a SPEC stage 1 (which i do believe has an organic disk and some have noted the resultant chatter)?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Dec 9, 2004
#12
  • Dec 9, 2004
  • #12
I believe the King Cobra is advertised as having an "organic lining" but I'm not for sure how much organic that means or is?
I got the King Cobra clutch for the price and "ease" on some of us daily drivers...but I'm sure the Spec is the equivalent of the King Cobra...
Yeah I've seen the Spec 2 have chatter problems but it has a much nicer power hold...just to on/offish for me... ...and plus I got to worry about my tranny...
HISSIN50
34
129
Dec 10, 2004
#13
  • Dec 10, 2004
  • #13
thanks 5spd. i had not seen nearly the chatter related gripes with the KC compared to the SPEC stage one. i was gonna get a stage 1 till read that. the stage 2 is kevlar, IIRC, but a lot more money.
i also have to worry about the 'weak link' in my drivetrain - dont want it not to be the clutch (but tires should be it - stocker size).
i appreciate the info - im trying to piece this stuff together for when the time comes.
V
v8only
2,378
22
49
Dec 10, 2004
#14
  • Dec 10, 2004
  • #14
the kc clutches rarely have chatter, and conversly, the specs are famous for it.
Kc clutches are good, but I wouldn't use one with much more than 300+ horses or so,or consistent quarter mile slick torture. Def won't break your trans
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Dec 10, 2004
#15
  • Dec 10, 2004
  • #15
Hey...I try to piece in what I can ...I just remember when ordering the clutch about the "organic lining"...
That chatter problem is what made me go with the King Cobra as well...
Don't talk about tires because that reminds I got to get some...I'm dangerously low on tread right now...and with Christmas and all...can you say "ouch"
HISSIN50
34
129
Dec 10, 2004
#16
  • Dec 10, 2004
  • #16
interesting. i have been following right along in your thought/logic path in terms of what clutch i would choose and why. scary and bad for you (that i am thinking along the same lines as you do).
dont tell me about it - i was at the tire shop today for the camaro.
in the meantime for you now, low tread is kinda like a slick.
had some other big expenses lately too. always at a time when expenses are already high (or the night before you leave on a trip).
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Dec 10, 2004
#17
  • Dec 10, 2004
  • #17
ive got a king cobra also and i like it. its got very good pedal feel and hooks nicely. i had a centerforce in before i did my tranny swap and i like the king cobra better. it just seems a lot smoother when banging through the gears. its a lot more docile than the centerforce i had which is good since it is my daily driver
2003-04 Mustang Cobra Brake Conversion
  • Cassiebaebae
  • Oct 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 24, 2026
Bib36`
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
2003 Mustang gt. Clutch overheating.
  • 2003 mustang gt modded
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jan 5, 2026
