King of the 60' Contest
Well after close inspection and there is still time to add to this as always. The results so far would be...
Street: 1.804 Brian15 (Pep Boys???)
DR's: 1.66 Killer (Must have been some ride all the way to the bar LOL)
Slicks: 1.54 TMC (how far she come off the ground?)
Also Joe what's the deal. Laggin behind are we?
I've heard those Pep Boys tires really do work!
And...not to be greedy but I also went 1.60 on DR's...I just really like cookies :D
Actually I don't think it did come off the ground, or at least not much more than a small patch of air under one tire???
:nono: Sorry Troy, I started this so I can make the ruels as I go along. :rlaugh: You can have the fastest in more than one class but only one cookie per person so it would revert to secong killer (as said in by law 50178; section 652-1;line 2; and i quote "A person can only win one cookie per contest.***Espically Troy*** "
the 1.804 i cut on the 235/60/15 was a one time deal the best i could get other than that was norm 1.84-1.86 the actucall type of tire is a delta gt roadmaster. ive had them on for close to a year now and there finally starting to show good wear and thats after usally racing at the track every friday night .
to tell the truth they get extremly sticky the sidewalls just dont wrinkle.
i ran them at 24psi and around 70$ a piece you cant beat em
Brian
:rlaugh:
I knew I should have read the fine print!
:D
Na, not falling behind.
I tore up the rear in my car on the first pass. I was doing a shake down pass and was just going to leave from 3500 to make sure it's not going to detonate or pull hard to one side or anything.
I broke the beams and the car stopped. I'll end up spending about 1000 bucks to fix everything the way I want to. It's just money....
Joe
NEW LEADERS!!!!
NEW LEADERS!!!!
Street: 1.9 from Rio5.0
DR: 1.66 Killer
Slicks: 1.54 TMC
Brian DQ'd from comp. after leading street, because of not having a 94-95 Sorry! (for any questions about rules ask troy).
Troy after re-reading everything and dq'ing brain you were leader of street with a 1.873 but as you remember only one cookie. So Rio5.0 cookie reverts to you.
TWO MORE DAYS TO GET IN YOR NUMBERS!!!!!!!!!!!!!!
Sautrday before I leave for Big Spring Jam I will post winners.
95WhiteVenom said:
NEW LEADERS!!!!
DR: 1.66 Killer
Slicks: 1.54 TMC
Is rio's lower than the 1.94 I posted? :D
Rules and Regulations...
:rlaugh: Troy is right... blksn955.o A 1.9 by rio5.0 would be faster than a 1.94 unless he says different until then his would be considered a 1.90. Rio5.0 I need a confirmation from you that it is indeed a 1.90. Just to clear up the questioning brought up by another contestant. Troy got a question? I see that in your sig., do you race real street? :nice: DONT WORRY it won't disqualify you from competition. Just wondering?
Rio please get this in before 2p.m. Tom. I leave to go to a concert and will give out the winners names around that time and wish to have the winners name marked clearly.
Thanks
15mins 32sec (behind tow truck) :(
