lambse, kams... rich?
Got a little datalogging with BE and now have a few questions. Most of the entire log the kams were .99x-.83x (rich?.) My lambse was anywhere from 12.x-18.x.
Does 1 or 0 is CL?
Does this mean I am running rich? My wideband is not working, so I can't use it. :mad:
Here is some brief simple info along the lines you ask of :D
14.7 is considered the standard for Closed Loop
> 14.7 is leaner
< 14.7 is fatter
LAMBSE is not your fuel ratio
LAMBSE is the value that the pcm is commanding at any given moment
KAMRF is a fuel trim OR your adaptive strategy at work is how I see it
KAMRF value of 1.00 is considered to be the standard for Closed Loop
< 1.00 means the adaptive is pulling fuel
> 1.00 means the adaptive is adding fuel
Now that you understand how it works ;)
Lets see if the values you've seen in your dlogs make sense :D
Your LAMBSE values are fat
thus
Your KAMRF values show the adaptive is pulling fuel to compensate
Does this not make sense ... that is if you're a 94-95 pcm :rlaugh:
OK ... OK ... I'm getting a bit ahead of things here
Trust me ... if you focus on the data events where you see the K's
active ... you are gonna see the LAMBSE commanding fat values
I'd have no comment on the 0 or 1 thing as I don't run that software
but
Inactive K's are usually and indication of Open Loop
Let me know if I made things better or worse for you :scratch:
Grady
It really seems that I am running on the rich side. I was looking through my datalog and it looks like I get CL for a few seconds.(unless the CL is not datalogging right) That is, if 1 = Cl. I guess that could make my run richer. :nonono:
I posted something about CL on eectuning.
I saw your dlog on the .org site and was gonna take a quick look
Can you put up the REAL file :)
I usually just look at a dlog in its raw data form when I wanna get a quick
big picture of things ;)
Grady
Grady
I dataloged with BE and that is how it saved it.
If you have eec anaylzer you can watch it like calcon shows it.
I bet your "Fuel - Injector Offset vs Battery Voltage" is throwing you off some, it looks like the stock J4J1 settings - is that what your tune is based off of?
Make another datalog with the params below. Get some good cruise, stop, start and into the throttle a bit (WOT not necessary):
  • LOAD
  • VBAT
  • PW2
  • PW1
  • KAMRF2
  • KAMRF1
  • LAMBSE2
  • LAMBSE1
  • MAF
  • RPM
  • SPARK
  • TP
  • MPH
  • ISCDC
  • STATUS1
  • AFR/EVP (if you have it)
EDIT: Start the datalog a couple minutes after you have started the car.
How confident are you that the MAF curve is right?
You are bottoming out your KAMRF's, something looks pretty far off.
Wes
not confident at all :notnice: I can't figure out this curve. When I used it with calcon I was lean at wot, so I tried with ea. Now it looks totally wrong at the lower values.
See if you can see the attached and look at it. I think I am going back to calcons and just tweak the top part
http://eectuning.org/node.php?rid=78
I am thinking the curve is a big problem
Post up the MAF transfer or tune with the MAF transfer in it (BIN format if you can).
Looks like you just cleared the KAM and the car was relearning?
Do some more driving and then take another datalog. This log does look closer than the other, however. :nice:
Wes
I richened my curve 2% all the way. On the newest datalog I noticed. During light throttle my lambse is 11.7-14.0 and kam is almost always above 1. But up to 1.09.
When I am about .5 throttle my lambse will be 11.2-13.65 kam 1.
i still feel like an idiot trying to understand all this but....
If my lambse is 11.7-14.0, and my kam is above 1(OL), that means the computer is sensing the car is lean. Is that correct?
My half throttle looks like its lean and rich.
I have not looked at my wideband, but last time at light throttle it was all over the place. Mostly rich.
log
http://eectuning.org/node.php?rid=84
here is my new curve
http://eectuning.org/node.php?rid=85
Should I have leaned the curve, not richen it?
The car thinks it is running lean.
The KAMRF is the adjustment it has learned (so 1.05 would be giving you the programmed fuel multiplied by 1.05 -- or 5% more).
The LAMBSE is the AFR that the car is actively trying to hit at that moment. When your tune is correct, the wideband and the LAMBSE will be very close to agreeing all the time.
Wes
You will see lambse active during CL and OL
The K's only come into play during CL
If you are wanting to work on the K's, it would not be of benefit to work with the
upper end of the maf curve as that is OL territory
Also ... You should not see the K's being active at throttle positions of 1/2 or more
as the load it too great to sustain CL at that much opening
I usually slip from CL to OL at throttle positions of 1/4 to 1/3 maximum
Here is where I think your frustration may be all about :)
I feel you are not quite grasping the basic functions of adaptive strategy which is
all about CL and how the K's are an indicator of being rich or lean.
You can work with the maf curve or the inj slopes but I feel the inj slopes are
the best way
I really never paid much attention to lambse when working with dialing in my
CL tune. I never paid all that much attention to what my wide band was doing
when working with my CL tune.
In a nutshell ... you dial in your CL tune as such
1) You load in your maf curve
2) Then you work with the inj slopes, offsets, and break point
You work with 1 then 2 ... but not 1 AND 2
If you do 1 AND 2 at the same time you are going to go in circles :crazy:
The objective here is to bring back in line the adaptive strategy to the point it
does not have to make large adjustments.
You want the pcm's adaptive strategy to maintain 14.7 at all conditions during
CL. It will have to make adjustments to do that but you tune to were it makes
small changes.
The pcm controls CL ... not you or not some table ... Make Sense
1.00 K's are considered not fat or lean
< 1.00 and the K's are pulling fuel cause you are too fat
> 1.00 and the K's are adding fuel cause you are too lean
BUT ... UNDERSTAND THIS
You are not controlling this ... You want the pcm to do it
The whole CL tune thing is about small throttle openings and very light loads
and
Driving conditions that don't meet those conditions are all about OL
and
Then the adaptive falls away and the tables come into play
and
Yes ... this is the part of the tune you do want to control
Have I made things more clear or I did just add to the confusion
Hey ... this stuff can be a bit mind blowing from time to time :rlaugh:
Grady
I would follow this path of action :)
Load in the curve from the sheet
then
Move over to working with inj values
Use info from past threads in this forum and the notes in EA to work with
inj slopes
inj offsets
breakpoint
min pulse width if you run large inj's
After you get things fairly stable you may see a point of two that is a bit fat
or lean and you can tweec the maf curve at those points but most have
found the amount of change needed to be very small.
It can take a while to dial in your CL tune using this method :(
but
It will be the best way as it will produce the most stable results ;)
Grady
