Last bolt on water pump?????
mustangfiveo198
145
Driving my STANG
OK,
I am doing a underdrive pulley and a A?C delete on my stang, I am up to the damn water pump pulley............I got off 3 of 4 bolts, now the question? How do you get off the 4th bolt? The pulley spins and I have nothing to stop it from spinning so I can loosen the last bolt. Any ideas?
Thanks alot. :flag:
put the belt back on, loosen all the bolts while holding down on the belt to cause a lot of tension. remove the belt and then back all the bolts out. you can also take a philips head screwdrive and slip it through one of the 3 holes and jam it up against the block or the water pump. that's a last resort though. good luck.
