Later model 4cyl swaps?
Fuzzylogic
42
Albany, OR
Hey all,
Just thinking out loud here. I plan on keeping my car as a really nice daily driver for the next 20 years, it's a '93 notch. Has anyone considered any other 4cyl swaps just for fun? The Focus jumps to mind first but I'm sure Ford has several other nice 4 cylinder engines. Maybe I need to wait a few years and just keep working on the interior and suspension and wait for someone to do a nice 4cyl turbodiesel.
I'm just thinking of newer engines, smoother with maybe a little more power with equivalent or better gas mileage. I really want to just have a very nice DD with a reliable, peppy, and efficient engine. Thinking maybe there are other options!
Well, one option is the Duratech 4 cyl found in later Focuses, and in many mazdas. There is a company that makes a bellhousing that will adapt a T-5 to it. The main two problems you would have are the motor mounts and the wiring harness. You could use a megasquirt system to solve the latter, and use any fab skills to solve the former. It wouldnt be the easiest swap, but its much more doable than a turbo diesel. To make it even better, remember that mazda makes a turbo version of this engine, and its all aluminum, so IMO its the best current choice
The Megasquirt is a homemade computer system designed for use a fuel injection control system.
http://www.megasquirt.info/index.html
The Ford Factory computers are encoded so you can easily modify them if at all.
By using a Megasquirt computer you can do pretty much whatever you want. If you take something like a 2.3L EFI turbo motor you can control every aspect of the fuel system.
Some of the guys on the fordsix.com forums are putting Tempo throttle bodies on a 200 I6 intake uisng a adapter and then controlling it with Megasquirt and getting really good gas mileage and driveability.
