Lead Addative
  • Thread starter Thread starter Fireman255
  • Start date Start date Apr 2, 2005
F
Fireman255
119
  • Apr 2, 2005
Do I need to put a lead addative in my gas? if so, how often and what kind?
D
D.Hearne
11,730
south louisiana
Apr 2, 2005
  • Apr 2, 2005
Wal-Mart stocks CD2 brand lead substitute. I was using this stuff for a couple years on my 68 Merc's 390, and never had problems with it. Can't verify that it actually does what it's supposed to do though, & I'm not going to take the heads off anytime soon to see either. Just from past experience with their products, they make good stuff. The bottle has a "dose" chamber and directions for use. The whole bottle treats about 350 gals. and cost's less than $10.
F
Fireman255
119
  • Apr 2, 2005
So I do need it for my 289
Pbum5
515
Minneapolis, MN
Apr 2, 2005
  • Apr 2, 2005
It depends. what year is your motor?
If you have a 60’s engine that has never been rebuilt then you should run some from time to time. If your heads were rebuilt with hardened valve seats then no.
If your engine has never been rebuilt it must be close to that time. I am assuming that a 40 year old stang has some miles on it if it’s all original.
F
Fireman255
119
  • Apr 2, 2005
I wish I knew what year the engine is of if it has bewen rebuilt. I got the car a couple of days ago and all I know is it got a new tranny last year
T
TOM B
20+ Year Stangneter
Nov 15, 2002
872
Harrisburg Pa
Apr 2, 2005
  • Apr 2, 2005
PMUM5 is correct. If you have none hardend valve seats like in all early engines then you should use it or the valves will wear into the seat and ruin them. If you have had your heads rebuilt with hardend seats then no you dont need lead. you dont need lead with any aftermarket heads.
F
Fireman255
119
  • Apr 2, 2005
so if I don't know, would it hurt to use it if it has been rebuilt?
D
D.Hearne
11,730
south louisiana
Apr 2, 2005
  • Apr 2, 2005
Better to be safe than sorry........ if in doubt----- use it.
F
Fireman255
119
  • Apr 2, 2005
Thanks guys....... do you have any input on my suspension thread?
T
THX 138
375
Los Angeles
Apr 2, 2005
#10
  • Apr 2, 2005
  • #10
umm lead is toxic.. stick with the substitue.
D
D.Hearne
11,730
south louisiana
Apr 2, 2005
#11
  • Apr 2, 2005
  • #11
No, lead itself isn't toxic. Lead fumes and dust are. And where did I tell him to use a lead additive? Plus, the amount of lead that one car uses to keep the valves lubricated isn't enough to harm anyone, unless he/she has their mouth wrapped around the tailpipe and is directly inhaling the exhaust. In that case, the lead isn't what's going to kill you, the CO is going to do the deed long before the lead ever will.
T
THX 138
375
Los Angeles
Apr 3, 2005
#12
  • Apr 3, 2005
  • #12
lead is toxic. Installation of lead pipes in ancient Greece and Rome wiped out whole settlements. anyhoo... Now-a-days CO and cigerettes will no doubt do you more harm than the amount of lead around now but its still bad for you.
http://dictionary.reference.com/search?q=lead
D
D.Hearne
11,730
south louisiana
Apr 3, 2005
#13
  • Apr 3, 2005
  • #13
There were and still are lots of century old houses here in the US that have/had lead pipes and you don't hear about wholesale deaths because of them. Lead is bad for you if ingested in large quantities but minute amounts are relatively harmless. I used to cast huge quantities of lead bullets and I'm still here. Of course I do occasionally suffer from "CRS" sometimes. Don't know if it was from the lead or "other" substances I used to ingest 20 something years ago.
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
Electrical V8 swap no power to anything
  • Bullittsmith
  • Sep 12, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 15, 2026
Mcmahst
A
90 Fox 4Lug rear convert to 5 Lug
  • adimice
  • Jun 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
limp
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
Fox Is it time to replace the coolant?
  • PonyGTrider
  • Sep 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
AeroCoupe
