Leak down test qestion
LONN17
135
Oceanport, NJ
*question*
I picked up a roller 302 w/ windsor jrs, Crane RR's, GT40 intake, 50lb injectors, blower cam, etc. a couple weeks ago for a song that will be going into my car when it finally gets back together.
I plan to at least do a gasket rebuild and check bearings etc. along with doing a leak down test before I disassemble it any further. My question is that since the heads are going to come off anyway; if I remove all the rockers, effectively closing all valves, can I avoid having to get on TDC-compression stroke (being lazy I know). I don't see any reason why this should give poor results....
Thanks,
Trevor
I think that would be fine. You would just feel at the throttle body and your exhaust side of the head for air flow to determine if its a intake valve or exhaust valve. If you feel air coming through your thermostat housing or waterpump you have a blown head gasket. From what I remember if you have 20% or less your good to go. Any higher than 20% you have some problems.
Steve69
Steve69
An engine built for street is acceptable with up to 20% leakage. A race engine should have no more than 10% leakage.
