• Off-Topic Hangout
Leaking Town car
  • Thread starter Thread starter Jinx
  • Start date Start date Jan 5, 2019
  • 3
1 of 3 Next Last
Jinx
I like cats, cats like me. Cats and I fully agree.
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Jan 5, 2019
  • Jan 5, 2019
At first I thought someone had spilled a soda and did not bother to tell me. So I just shop vacc’d it and let it dry out. Well after 4 days of rain I noticed condensation build up inside so I opened the doors to see and there was about 1/2” of standing water. It’s only on the passenger side. It’s more pronounced in the back. The windows were up and the door seals look like they are in good shape. What I want to know is how is the floor getting soaked but there is no sign of water damage or dampness any where else ?
Jinx
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Jan 5, 2019
  • Jan 5, 2019
More pics
Jinx
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Jan 5, 2019
  • Jan 5, 2019
Some of exterior joints
Jinx
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Jan 5, 2019
  • Jan 5, 2019
So after 20 min of running the car on high recirculating heat, followed by to hours or radiated heat (safely) I pulled another 2 cups of water from the rear passenger floorboard.
Admin Dude
Jan 4, 1985
43,421
21,628
234
Box behind Walmart
Jan 5, 2019
  • Jan 5, 2019
All of those images are so closed in that it's hard to tell from shinola.
Is it a sunroof car?
front seat, back seat, both?
Was it sitting? Being driven?
also: pics of the cowl, rear window, jambs in the trunk
What drain tubes to Town Cars have? You already check evap drain?
Reactions: Jinx
Jinx
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Jan 5, 2019
  • Jan 5, 2019
No sun roof
Both front passenger and rear passenger floor boards are wet. More in the rear.
Definitely sitting for several weeks
Not familiar with this car as it is not mine do no idea about drams or tubes.
I can see about getting requested pics later.
What’s really weird is that there is zero dampness above 2” from the floor boards.
RaggedGT
Mod Dude
Jul 20, 2014
4,756
3,213
203
Taylorsville ky
Jan 5, 2019
  • Jan 5, 2019
Back when I still did automotive ac-used to always be the hvac box,either the drain for the box would be clogged,or the drains in the cowling would be clogged and eventually make its way to the hvac box,and then overflow into the floor. A car that sits usually has a cowl panel full of leaves and other junk
Jinx
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Jan 5, 2019
  • Jan 5, 2019
Will look at that tomorrow.
General karthief
Mod Dude
Aug 25, 2016
28,080
10,695
213
polk county florida
Jan 5, 2019
  • Jan 5, 2019
Pull the kick panel on the passenger front, could be a cowl or windshield leak and running down the inside and out a seam at the floor
Jinx
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Jan 5, 2019
#10
  • Jan 5, 2019
  • #10
Added to list of to do’s
Jinx
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Jan 6, 2019
#11
  • Jan 6, 2019
  • #11
Pics as requested
One or two leaves in the cowel and completely dry.
Jinx
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Jan 6, 2019
#12
  • Jan 6, 2019
  • #12
Floor boards damp again but not nearly as bad. Must be something holding the liquids like a sponge.
Jinx
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Jan 6, 2019
#13
  • Jan 6, 2019
  • #13
Pulled the front kick plate and pulled back carpet. Pool of water sitting under mat. Trying to load video after picture.
Jinx
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Jan 6, 2019
#14
  • Jan 6, 2019
  • #14
No luck with video now
Jinx
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Jan 6, 2019
#15
  • Jan 6, 2019
  • #15
Cowel removed and carpet pulled back. That rubber barrier is soaked. Also starting to get drainage through weep hole in floor.
Admin Dude
Jan 4, 1985
43,421
21,628
234
Box behind Walmart
Jan 6, 2019
#16
  • Jan 6, 2019
  • #16
You need to look behind all of the door panels and see if the drain holes are plugged.
If it's been sitting for a while, the door bottoms can fill and overflow into the car.
Jinx
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Jan 6, 2019
#17
  • Jan 6, 2019
  • #17
I don’t think it’s the doors because it’s completely dry at the door sills. Even under the runner from the kick plate.
Jinx
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Jan 6, 2019
#18
  • Jan 6, 2019
  • #18
Rear seat removed. Rear passenger trim pulled and carpet lifted... so much water !!! Think it may be left over from when it rained with the windows on that side down? Granted that was 7 weeks ago that it happened but I never considered the extent of water trapped in the foam?
Jinx
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Jan 6, 2019
#19
  • Jan 6, 2019
  • #19
Holy chit!!
Admin Dude
Jan 4, 1985
43,421
21,628
234
Box behind Walmart
Jan 6, 2019
#20
  • Jan 6, 2019
  • #20
That water will stay under the carpet for a loooooooooooooooooong time.
I fought similar to issues to what you're having on my daughter's Cadillac CTS. Their ended up being one large contributor and several small ones that I found. One of the small ones was fixed when the windshield was replaced.
That car had 'junk' in nearly every water drain. The previous owner had obviously kept it parked beneath one of those trees that poops the little helicopter thingies along with some tiny popcorn looking stuff.
Reactions: Jinx
  • 3
1 of 3 Next Last
Interior and Upholstery Inside door flex when window rolls up fully
  • beeduckworth
  • Sep 19, 2023
2K
Fox 5.0 Mustang Tech Sep 21, 2023
limp
Weatherstrip issue
  • 1hot87gt
  • May 15, 2022
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 25, 2022
chrlsful
C
O
2017 Mustang GT Driver Power Window Oddities
  • ou18
  • Jul 17, 2023
  • 2015 - 2023 Specific Tech
2K
2015 - 2023 Specific Tech Jul 17, 2023
ou18
O
87 LX 'Vert
  • fun331
  • Jun 15, 2023
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 30, 2024
Mustang5L5
Progress Thread H/C Swap Problems/Ideas
  • sav22rem22
  • Mar 31, 2024
2K
Fox 5.0 Mustang Tech Sep 10, 2024
AeroCoupe
  • Off-Topic Hangout
