Learned something new tonight...
Black1987Stang
1,422
Jersey Shore
A car will Barellyy crank over and have a nice grinding sound while its at it if the starter retainer bolts are missing/hand loose :rolleyes: ...Ive been having a big problem with the starter lately, It cranked but was very slow and sounded like it was grinding or something...tightened the starter as much as i could, check battery, the works, still the same...I grabbed the starter and rotated it ccw and cw and it moved...With the starter bolted to the bell housing haha, The 2 long 10mm bolts that hold the starter together, one was missing and the other was hand loose...tightened the one up and was back to normal, it still makes a little rough noise but should clear up once I get another bolt in the starter...anybody no if i can get one of these long bolts at the parts store? I dont feel like taking the one out of my starter now in the hardware store parking lot to get a new one.....while I was under there I also noticed my upper tranny bolt looks like it backed out a hair, i fit my fingernail between the bolt and the casing...and the bolt under that one is missing :rolleyes: always has been, hmm maybe thats why my 1st gear is winding now once i get above 1500rpm
9050lx said:
My wifes 5.0 HO E-150 actually dropped the starter on the ground and broke off the mounting ears, I really never found out why.
Probably because the bolts fell out. :rlaugh:
Just messin.
Vibration and the torque of a starter motor can loosen bolts without a ton of fuss.
For the original poster, the starter achieves much of its ground via the connection to the bell. Once it starts to come loose, the crap ground connection leads to slow cranking, even if you connect jumper cables to a power plant.
Thats what I figured, it already started cranking slow again and making that grinding noise or whatever. time to go to the hardware store or pull-a-part to get a new screw
if i remember right the upper bolt is a shorter one, and maybe the bottom is longer..find someone that has an assortment of old bolts and find what you need, it you grind on it too much you'll need a new flywheel..it will grind the teeth off it, or at least down some on a properly working starter..just think how yours is....fix it quick dont let it become a major issue
~Mark~
~Mark~
ur talking about the bolts that hold the starter onto the bellhousing right...Im talking about the ones that hold the starter together...holds the case with the magnets in it to the other section with the spur gear in it...i put a longer top bolt that holds the starter to the bellhousing and put a nut on the back side of it and tighten it against the bellhousing cuz the top starter bolt use to always come loose. I checked my flywheel 2 weeks ago and it was all good, its a billet steel one btw. ill prob just get a reman one from napa or something, i get a discount there anyways, just till i can get a real nice mini one...mine looks like the original one from 1987 :eek: anyways.....I know in 1993 they started putting much smaller and lighter starters in the stangs...is there anything else good about them? r they more powerful...theyre more pricey than an 87 in the store, 75 bucks compared to 35 bucks for an 87 remany
