What's the MAF part number on the electronics?stock A9L ECU, the MAF is a 70mm Crown Vic for 29 lbs injectors.
If its F2VF-12B579-A2A, those work with 19# injectors. If it's anything else, it will not work with the A9L without tuning. Factory OE Maf's are not "calibrated" to injector size. They output a transfer function that the ECU interprets and converts for injector size. The F2VF-12B579-A2A MAF just happens to have a similar transfer function to the OE E9/F1 Maf so it works, but anything else will not.
I actually run the F2VF-12B579-A2A 70mm MAF on my combo with an untuned A9L and 19# injectors and it still runs rich. If you are running larger injectors, it's probably VERY rich.
EDIT: now that i go back and reread, sounds like the 29# was a typo and you meant 19#
