Lets play, what is this cut wire?
tuhockey11
81
PA
Looking around under the hood today i noticed a few things out of place near the starter solenoid on the drivers side fender. First, there is a thin red wire with a blue stripe (looks factory) that has been cut and is just sitting there, what is this? Second, there is a large gauge wire (not factory), going from the solenoid into the interior via the firewall grommet. WHat could this possibly be for? Any help appreciated
the large guage wire could have been from a large aftermarket stereo, although mine was wired directly to the battery with an inline fuse... try pulling up the drivers side carpet and then tracing where the wire goes. if it goes to the trunk/hatch, it was likely for big subs.
Wouldnt the car not start without that wire hooked up to the solenoid? Car starts and runs fine. I should have clarified, the large wire is not like a stereo wire, not wuite that big. The car has a mini starter, could this explain these wires?
I may be wrong here but I thought the sn cars had what the factory called a "mini" starter but wired the same. It was smaller and lighter than the fox starter but fit the same with more torque. I know an aftermarket one would wire different or custom. (thats what I meant one my prev post)
The small red/blue wire goes two places on a stock Mustang: the small push on stud
for the starter solenoid and the TFI module. Both locations are energized only when
the key is turned to the Start position.
Diagram courtesy of Tmoss &Stang&2birds
attachment.php
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
