Let's see your SBF 94/95 Trigger Wheel Setups
beyondEOD
106
12
28
Indiana
Does anyone have an economical trigger wheel setup with crank sensor bracket they can share.
I've seen a few with the trigger wheel mounted between the balancer and the pulley. Did this cause any alignment issues with the belt system?
What I'm looking at so far.
DIY Wheel
Escort sensor
So I used a 36-1 wheel and spacer kit from 64-bit tuning with the aftermarket balancer it made belt alignment easy. The sensor is a hall effect I had sitting around, the same one can be purchased from diyautotune. I took a timing pointer and modified it with some sheet metal for the sensor mount. Works great.
Another 94/95 bug bite.
Looks like I need the following to do this if I wanted it between the balancer and pulley.
1. Diyauto 6.75 wheel
2. DIY auto threaded sensor
3. Innovators west .300 spacer
4. Machine down balancer .300 plus
Major pain.
Any reason I could not mount out in front of the pulley with some spacers?
why not see if the trigger wheel fits on the back side of the balancer? thats how I have done it in the past.
No reason why you cannot place it in front of the pulley except for possible belt issues..
You always have the option of using a cam sync or a CAS type setup.
That might work on the back. Do you tack weld it in place?
