Well I wanted to create a thread about the (in) famous injector offsets vs. battery volts. Its a really wide and open discussion on other forums however I want to gather all the experience on self tuners here, I had my tune pretty much done, but I was not satisfied on the maf curve after all, I looked like a Z on some parts, so in the eternal and addictive "Perfect tune research" I headed to rewrite all my parameters from scratch.
And to the point, researching the Breakpoints, slopes and this i concluded that is more easy/efficient? Have both slopes set equally (30) but this heads to the offsets had to be near perfect, if you have been around on the self tuning some time probably you had seen that all the combos report different numbers on the same injectors. Let’s take a look on some examples:
EEC Analyzer says that for 30 lbs you should use this:
16.00 0.6333
14.00 0.6344
13.00 0.7175
12.00 0.8854
11.00 0.9592
10.00 1.3405
9.00 1.4667
8.00 2.0394
7.00 3.0400
6.00 4.6800
4.80 7.0000
3.20 7.0000
1.60 7.0000
0.00 7.0000
On the mustang-tech you get these ones:
10 1.300
11 1.110
12 1.00
13 0.900
14 0.725
15 0.725
As you can see the numbers increase instead of decrease?
Grady Has this ones on his combo:
6 5.75
7 3.75
8 2.9
9 2
10 1.6
11 1.13
12 0.97
13 0.79
14 0.63
16 0.69
All of them are boring as hell to compare on numbers, but the differences really come up when you see them on a graph:
I want to keep this thread the most informative and tech so the info that could be posted here can be added to the very valuable mustang tech, and complement all this information.
All this values can vary because a numberless factors on this combos because different mafs/injectors/slopes but in my case i want to know how are you dealing with this differences , generating readable voltage of +14 or -12 it seems pretty much impossible since you already are walking on ice cake at those volts by ruining your electrical component by over voltage and not running efficiently on lower volts, i know any healthy stang would be on the 12-14 area normally , i want to share with you a possible idea, by using for example E.A. Get the best offset on a normal area ex. 13-14 and smooth other areas according to the tendency.
Well this is a share information and keep a dynamic post on this since its important to the new sel tuners to know how to cope with this critical function.
There you go! Keep those comments coming
16.00 0.6333
14.00 0.6344
13.00 0.7175
12.00 0.8854
11.00 0.9592
10.00 1.3405
9.00 1.4667
8.00 2.0394
7.00 3.0400
6.00 4.6800
4.80 7.0000
3.20 7.0000
1.60 7.0000
0.00 7.0000
10 1.300
11 1.110
12 1.00
13 0.900
14 0.725
15 0.725
6 5.75
7 3.75
8 2.9
9 2
10 1.6
11 1.13
12 0.97
13 0.79
14 0.63
16 0.69
... as I see it
