Ok, so I’ve gone down a bit of a rabbit hole.
While putting on the old TB, one of the nuts cross threaded on the stud, and while removing it I noticed they were different lengths, like a couple of them had been installed backwards.
I decided to just pull off the egr spacer to see exactly what I was dealing with, and while removing the spacer the gasket fell apart and I was greeted with this:
There’s a whole lot of shmoo and moisture (I’m assuming condensation) in and around the mating surface and the water jacket of the spacer, which makes me think that the gasket had been deteriorating over time, and may be where my leak is coming from. The small gaps in the paper gasket could have filtered the smoke during the smoke test and prevented me from seeing it.
I’m planning on ordering new studs and gaskets, I’ll probably put it all together and find that this wasn’t the problem at all, but it’s the theory I’m working under right now.
Would a solid egr spacer prevent this kind of moisture buildup and deterioration from happening?
I did look at the inside of the IAC:
I freely admit I’m not sure what I should be looking for, but it looks pretty clean.
