Lifter adjustment
  • Thread starter Thread starter SMOKEDYA
  • Start date Start date Jun 14, 2006
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Jun 14, 2006
  • Jun 14, 2006
So on my coupe i have some seriously tapping lifters. What is the proper way to adjust them? They are the ford motorsports/cobra 1.7's. peace
john
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jun 15, 2006
  • Jun 15, 2006
are these pedastal or adjustable? if they are pedastal there is no adjustment just torque em down to 18-20 ft/lbs. if they are adjustable then follow the instructions in this link
doh i couldn't open the link some trouble with adobe. anyways go to comp cams go to instructions. scroll down to magnum rocker install and follow the instructions for hydraulic lifters.
smittyb
134
Marysville,wa
Jun 15, 2006
  • Jun 15, 2006
The cobra's are pedestsal. Use shims.
V
v8only
2,378
22
49
Jun 15, 2006
  • Jun 15, 2006
that's completely 100% incorrect.
As posted by the next guy, use shims. Go to the crane site, they have the correct procedure for roller rocker adjustment. shims can be had for about $8 from summit.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Jun 15, 2006
  • Jun 15, 2006
So i should go to the crane site check the procedure and get the correct shim pack? If i remember right the guy that builtthe car said they kept backing off so he used diffrent bolt's or something to that degree? Is this process a pain in the ass or does it just sond confussing? Oh BTW what is there address for crane? I'm internet stupid! peace
john
V
v8only
2,378
22
49
Jun 15, 2006
  • Jun 15, 2006
i believe it's cranecams.com
there will be directions there, you need to know how to search. it's a pain in the ass, but the only way to get it dialed in correctly.
C
COP TZER
25
VA
Jun 15, 2006
  • Jun 15, 2006
Seems like someone knows about as much about rocker arms that they do about making a car hook.
carbed87
215
  • Jun 15, 2006
yeah, i used the crane directions when i was in youre boat.
you probably won't want to do this, but pull off you're lower plenum, and MAKE SURE youre getting at least 20thousands pre-load on the lifter. lol, when i did heads on my car, i found out that the rocker arms were bottoming out on the pedistule before i got the correct preload on the lifter.
and i thought that you only need to shim you're rockers if you have too long of a pushrod...
but yeah, give that a try.
smittyb
134
Marysville,wa
Jun 15, 2006
  • Jun 15, 2006
Yeah, you need shims when you can't reach the desired 18-20 lb-ft within 1 turnof zero lash.
I was just kinda responding to what the guy above me had said.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jun 15, 2006
#10
  • Jun 15, 2006
  • #10
sorry bout my incorrect data. just curious how putting a shim in makes the tick go away? these shims must be shorter then the factory mounts?
smittyb
134
Marysville,wa
Jun 15, 2006
#11
  • Jun 15, 2006
  • #11
OK, my first post I was just replying towards your (86blue) first post, my second post I was just replying to carbed87's post. Now I am replying to your post again. Does that clear things up?
There is adjustability with pedestal mount rocker arms. It is a combination of pushrod length and shims.
C
COP TZER
25
VA
Jun 15, 2006
#12
  • Jun 15, 2006
  • #12
Its ticking cause it has way too much valve lash.
Should be somewhere between .025-.028
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
C
Flat tappet to roller lifters--older block
  • chazmanaz
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 27, 2026
D
Rockers, lash adjusters and timing: help with parts (4.6 2v)
  • dvigAtel
  • Nov 1, 2025
  • Other Auto Tech
Other Auto Tech Nov 1, 2025
dvigAtel
D
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
