Lifter Blead Off
Bligaderski
28
Tennessee
What would cause lifters to blead off after you park and let the motor sit for a few hours. I thought it was bad lifters, replaced them and its still doing it. After the car runs for a few minuets it stops tapping ( theres a few of them tapping at first then one and then none). This is driving me crazy, I'm going to do a rebuild in the next few months so im trying to figure this one out before i tear down.:shrug:
the problem mor ethan likely isnt your lifters. as they bleed down everytime the car is off. especially if the oil is hot and thin. i would also check to make sure all pushrods are not bent and show no signs of damage on the ball ends.
the lifters you are describing might need more oil in them than the others to compensate for a bent rod.:shrug:
a few months back i had a few bad stock rockers and they madea sond similar to bad lifters and i wound up replacing all f my lifters and not fixing the problem.
