lifter noise. worry?
fiveoho
1,958
TN
if i really lay into it, around 4500 and above it starts to 'ping'. cant really make a good description of it. not really ping...rattle. i dunno. the car has 108k on it and never been into. doesnt smoke, runs smooth. no funny noises while idling and normal driving. if i mix a few gallons of 110 with a tank of 93, it wont do it. after i fill up several times after that, it starts again ( only done the 110 mix 3 times in 2 years )
this something to worry about? is it my lifters? is this this a problem?
thanks guys
I agree with 04sleeper, sounds like pinging from too far advanced timing.
Pull that Hypertech chip out and I'll bet it goes away.
EDIT: For a better explaination, most aftermarket off-the-shelf chips advance timing to give you increased performance. The chip is probably advancing your timing too far, especially if you have set your base timing above 10*, to say 14* like lots of guys do.
Jeff
i will have it checked tho just for the sake of argument. whats the stock timing suppose to be set at? how should i compensate for that with that hypertech chip. main question : what optimal timing can i run to where it wont do that??
if not timing, any other ideas?
The stock timing is 10 degrees with the spout out. Not sure what the Hypertec chip adds to it.
Try bumping it back 2 degrees at a time until it stops.
Are all of the tune up items in good working order?
What plugs are you running? What gap?
the wires 'look' good . they are fms 9mm but i have no idea how long they have been on there. ive had the car going on 3 years and havent changed them. changed the plugs about 2 years ago. put motocraft plugs in.....cant remember what i gapped them tho :doh:
time for wires? also, havent dont cap or rotor either
-thank u for your help
04sleeper said:
Not really. It could just be covering up another issue.
I would do a good tune up. Autolite 25's, New wires, cap rotor.
Then go from there.
i already have a set of new fms 9mm wires at home . i can order a cap/rotor for around 20. plugs are prob 20 or less and i may get a coil.
i think i may try that...tune up. you think it may solve my problem? going to check the timing as well
bet its timing.... get a timing gun.... just got one for 10 bucks on ebay and its worth 80 bucks if i bought it new.... just something for you to check out... or take it to a shop they might do it for free.... takes 5mins
I wouldn't worry about the coil.
Check the timing and see where it is set at.
Roland69 said:
it wont hurt but I would check your timing befor you do anything It only takes 5 minutes to do. I bet you need to retard it a bit.
yea, i will def check it. but i havent changed it and it was doing this before the hypertech install.
5 min check tho is def worth it
