  • SN95 4.6L Mustang Tech
Lifter Tap Problems
  • Thread starter Thread starter fastford03
  • Start date Start date May 27, 2012
fastford03
35
Southside Indianapolis
May 27, 2012
  • May 27, 2012
When I start my car in the morning or after it sits for awhile the lifters tap real loud and fast then fade. Is this something normal for the 4.6 or should I be worried?
trinity_gt
3,125
81
99
Canada
May 27, 2012
  • May 27, 2012
What kind of oil filter are you using?
Some have inferior anti-drainback valves which allow the oil galleries to drain while the engine is off. This can lead to clatter upon subsequent starts as it takes a few seconds to get oil back into these galleries.
The Motorcraft FL820 has a very good valve in it and helps prevent this.
fastford03
35
May 27, 2012
  • May 27, 2012
I just bought the car 2 weeks ago so I'm not sure what kind of oil filter it has.
Clayton302
79
Hurricane Utah
May 27, 2012
  • May 27, 2012
Change your oil with a synthetic like Mobil one. you should do that now and not wait. also do what was mentioned by trinity above. I had a bad experience with one of fram's X2 like $15 filters and lost oil pressure. keep an eye on your oil filter gauge. if it flutters when you step on the gas your filter is clogged or cant drain back.
blkstanger
45
El Cajon Ca.
May 28, 2012
  • May 28, 2012
I wouldn't run anything but a Motorcraft filter on these motors.
fastford03
35
May 28, 2012
  • May 28, 2012
The car had the oil changed with full synthetic at the dealership and I'm pretty positive they used a motorcraft filter. Not 100% tho
P
phatboy5015
60
Jun 3, 2012
  • Jun 3, 2012
I don't know if it's normal, but my 03 F-150 5.4 does it about 50% of cold starts. Just for about half a second. Been doing it for the 2 years I've owned it, no problems, and hasn't gotten worse.
fastford03
35
Jun 3, 2012
  • Jun 3, 2012
Must just be a ford thing bc my moms explorer does it and so does my mustang only for a quick moment then it's fine so I'm not to worried unless it keeps on after I'm up to temp
P
phatboy5015
60
Jun 4, 2012
  • Jun 4, 2012
I've run Mobil 1, K&N, Fram, Wix, and Motorcraft in my F-150. Still had lifter tap at startup sometimes with all of them.
Rejekt
546
Raleigh, NC
Jun 4, 2012
#10
  • Jun 4, 2012
  • #10
My dads F150 had the same issue... Was still doing it when he traded his in with 180k on the odometer.
I've always used Mobil 1 with Fram tough guard filters and never had an issue.
MaxedGT
304
Surrey BC Canada
Jun 4, 2012
#11
  • Jun 4, 2012
  • #11
Mine did the same thing with a Fram oil filter. I only use AC Delco filters currently and never had a tick with them.
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
W
2003 Mustang GT issues
  • westberry23
  • Aug 25, 2025
SN95 4.6L Mustang Tech Sep 24, 2025
squeak93
C
Valve stem tip tap?
  • Coolen
  • Apr 6, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 14, 2025
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
D
1996 gt mustang block temp vs coolant temp
  • Dkuehn
  • May 21, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 22, 2026
squeak93
