When I start my car in the morning or after it sits for awhile the lifters tap real loud and fast then fade. Is this something normal for the 4.6 or should I be worried?
Some have inferior anti-drainback valves which allow the oil galleries to drain while the engine is off. This can lead to clatter upon subsequent starts as it takes a few seconds to get oil back into these galleries.
The Motorcraft FL820 has a very good valve in it and helps prevent this.
Change your oil with a synthetic like Mobil one. you should do that now and not wait. also do what was mentioned by trinity above. I had a bad experience with one of fram's X2 like $15 filters and lost oil pressure. keep an eye on your oil filter gauge. if it flutters when you step on the gas your filter is clogged or cant drain back.
I don't know if it's normal, but my 03 F-150 5.4 does it about 50% of cold starts. Just for about half a second. Been doing it for the 2 years I've owned it, no problems, and hasn't gotten worse.
Must just be a ford thing bc my moms explorer does it and so does my mustang only for a quick moment then it's fine so I'm not to worried unless it keeps on after I'm up to temp
