  • SN95 4.6L Mustang Tech
Light behind gauges busted...
  • Thread starter Thread starter DarkHorse02GT
  • Start date Start date May 13, 2004
DarkHorse02GT
156
Tuscaloosa/Mobile, AL
May 13, 2004
  • May 13, 2004
One of the little lights that makes the gauges glow burned out apparently, can't see the left side of my speedo at night. Is this something I can easily fix myself or should I just blow it off and take it to the dealership?
JonJon
4,801
back in Marylands
May 13, 2004
  • May 13, 2004
If it's under warranty, let them do it...
DarkHorse02GT
156
May 13, 2004
  • May 13, 2004
I usually say that but unfortunately i'm 626 miles outside of my warranty. I really don't want to pay them some stupid amount of money just to do something I might possibly be able to do.
streetstang03
unModerator
Dec 27, 2003
the dark side of the moon/home of the 1999, 2003,
May 13, 2004
  • May 13, 2004
may be a good time to add some white face gauges. i bet u will have to take the gauge cluster out of the car to replace the light. why not add some white face gauges while u have it apart??
DarkHorse02GT
156
May 13, 2004
  • May 13, 2004
Yah I did think about that but I realized I like the stock black ones better... i'm attempting to make the whole car black right now and white face gauges just wouldn't fit right with the overall look of my car (tinted tails, dark window tint, experimenting with tinting spray and clearcoat to make my emblems look black chrome, that kinda thing.)
streetstang03
unModerator
Dec 27, 2003
May 13, 2004
  • May 13, 2004
hows the emblem thing going? if u figure that out, post how u did it and some pics. thats a pretty slick idea!!
A
Ajax_02GT
90
Austin, TX
May 13, 2004
  • May 13, 2004
If it's anything like my wife's old '96 Explorer, it was just a matter of pulling the guage cluster out and replacing a bulb. Each bulb is just plugs into a little socket. It was pretyy self explanatory once I got the cluster out.
DarkHorse02GT
156
May 13, 2004
  • May 13, 2004
StreetStang03: Yah, I did one today on the pony in an extra grill I had laying around... looks pretty good, with the tinting spray i used some of the chrome still shines through then the clearcoat makes it nice and reflective... as soon as I get a digital camera from my friend ill take pics and post a new thread on it... I want Stangnet's opinion before I do it to my actual car.
Ajax: Thanks man I guess Ill look up the bulb type and give it a try if its that simple.
merc123
420
North GA
May 13, 2004
  • May 13, 2004
As crazy as this sounds, disconnect the battery for 30 minutes then reconnect. My cougar dash went out and half my tach and all the guages on the right side went out. I disconnected the battery to do something to the car and it fixed it. I had them "out" for about 2 weeks before the battery thing.
DarkHorse02GT
156
May 13, 2004
#10
  • May 13, 2004
  • #10
Well damn, ill try that right now... thanks merc
todd4566
1,075
California
May 13, 2004
#11
  • May 13, 2004
  • #11
Fixing a dash bulb is easy. Yank off the headlight knob, remove the gauge trim, and unbolt the cluster. There are only two wiring harnesses connected to the cluster; they even have clips to make removal easy .
merc123
420
North GA
May 14, 2004
#12
  • May 14, 2004
  • #12
I just wanted to make you look stupid. J/K. Did it work?
DarkHorse02GT
156
May 14, 2004
#13
  • May 14, 2004
  • #13
j/k No it didnt, but thanks Todd, I'll try it tomm.
merc123
420
North GA
May 14, 2004
#14
  • May 14, 2004
  • #14
Who's Todd?
DarkHorse02GT
156
May 14, 2004
#15
  • May 14, 2004
  • #15
merc123 said:
Who's Todd?
todd4566 the guy who posted a few posts up... I forgot the numbers so just typed Todd... wow this thread got :OT: oh well
merc123
420
North GA
May 14, 2004
#16
  • May 14, 2004
  • #16
WaltA
230
May 14, 2004
#17
  • May 14, 2004
  • #17
todd4566 said:
Fixing a dash bulb is easy. Yank off the headlight knob, remove the gauge trim, and unbolt the cluster. There are only two wiring harnesses connected to the cluster; they even have clips to make removal easy.
One should not even have to remove the wiring harnesses. There is enough play in them, to be able to pull the cluster out and tilt it forward. The back of the cluster will then be point up, and you can easily reach the bulb sockets. The five white colored sockets are for the lighting, and grey colored sockets are for the idiot lights. They just twist 1/4 turn counter-clockwise and pull put.
The worse part is removing that headlight knob. After that, it should only take about 15-20 minutes to do.
DarkHorse02GT
156
May 14, 2004
#18
  • May 14, 2004
  • #18
Havent looked at it yet this morning, but how do you remove the headlight knob?
EDIT: Nevermind, I found out how.
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
  • Gulftown980x
  • Jul 29, 2026
squeak93
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
