  • 1994 - 1995 Specific Tech
lightning 90mm / mac cold air ?
  • Thread starter Thread starter mustangt562
  • Start date Start date Mar 13, 2006
mustangt562
226
Long Beach
Mar 13, 2006
  • Mar 13, 2006
Hey fellas, just wondering will a lightning 90mm mass air flow meter fit with a mac cold air intake? And are 42lb injectors mandatory or can I use 30lb's?
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Mar 13, 2006
  • Mar 13, 2006
I would not know about the cai thing
All Ford oem mafs do not fall in the category of the maf is caled for certian size inj thing
or
Cheat mode as some call it
That maf does happen to be able to support air flow that 42lb inj's would typically be used with
You could use that maf with 30's but you would have to get inside the pcm
Grady
rustang94
281
Milwaukee WI.
Mar 14, 2006
  • Mar 14, 2006
You will need a chip or you will run way to lean. The best set up I found was a C&L pipe a 3.5" to a 4" adapter (I got from race part solutions www.racepartsolutions.com ) and a 96 gt C&L filter and shield (the filter is a super tight fit) at lest thats what I did. You probably could use a adapter on the mac coldair but I think you would have to fab something up for an airfilter. As final5-0 said you can get the tune on the chip for the injectors. Also you will need a lightning mass air harness, or a lightning harness adapter from http://www.musclemotors.com/index.asp?PageAction=VIEWPROD&ProdID=1066&HS=1 I do have this Lightning harness adapter sitting in my room I will be willing to sell for a lot less if your interested? Here is a link from when I did the swap http://forums.stangnet.com/showthread.php?t=608796&highlight=lightning+mass+air hope this helps. Pm me if your interested in the lightning mass air adapter.
mustangt562
226
Long Beach
Mar 15, 2006
  • Mar 15, 2006
sounds like what I was thnking for my setup.
Can you post a pic of your setup? I would really really appreciate it
Joe 5.0
1,184
Macomb, MI (metro detroit)
Mar 15, 2006
  • Mar 15, 2006
rustang how much u want for the adaptor? and is it new or used? pm me
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Fox Mass Air Flow 42lb injectors
  • 89wreck
  • Aug 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 5, 2025
Scrapla347
Pro flow serial number
  • Andresquintana.mma
  • Mar 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 19, 2025
Andresquintana.mma
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
