like dropping anchor mid-track
  • Thread starter Thread starter glxrustang
  • Start date Start date Nov 26, 2008
G
glxrustang
Indiana
Nov 26, 2008
  • Nov 26, 2008
Okay, I have all high rpm parts, and falling on my face at high rpm..what gives?! 302 flat top pistons, 210cc Aluminum heads, funnel web intake, 750 DP with a proform mainbody, and f303 cam(which might be the problem). Also a transbrake, 3300 stall convertor and 4.10:1 gears. All this equates to 14.7 ET constantly...
Now here's the paradox, with the E7 iron heads, performer rpm intake, e303, and 650 cfm DP the thing ran 13.9s. Thats with the T5 and 3.55:1 gears. This setup is more street and less race, but ran faster.
So what happens when valve springs are too weak? (i dont think i remember valve float) Or maybe my cam is installed too advanced(cuz I have surpising low speed torque). Or could it be lazy air flow(whatever the heck that is).
Does anyone have solution to this? Maybe an engine builder or something has an opinion. Its just not accelerating properly. Same sortof thing happened when my fuel filter was clogged, or when my secondaries weren't opening fully.
Thanks for looking
ttop88
42
indiana
Nov 26, 2008
  • Nov 26, 2008
Funnel web is too big for most drag engines. What fuel pump are you running? I would bet you are running out of gas.
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Nov 27, 2008
  • Nov 27, 2008
solution: dont drop anchor half track....
G
glxrustang
Indiana
Nov 27, 2008
  • Nov 27, 2008
holley blue pump 114 gph(freeflow) and -8 feed and -6 return lines thru an aeromotive bypass regulator. I am wondering about the blue pump. I will add an A1000 since I will be adding a turbo this year. (Check out my cardomain site, page 2)
I've been told the funnel web is too extreme, but isn't it supposed to kill low end and boost top end? At what rpm would it really kick in? And if I use my GT45 turbo will that end the lazy airflow?
So far, blue pump and funnel web intake are the suspects...
G
glxrustang
Indiana
Nov 27, 2008
  • Nov 27, 2008
Oh and from the newbie to yall, Happy Thanksgiving!
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
F
carb vs cam help needed
  • forango
  • May 2, 2024
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2025
forango
F
94 GT HCI: Won't find /hold idle when Warm to Temp
  • 1994FiveO
  • Jun 10, 2023
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jun 14, 2023
1994FiveO
T
1989 GT Possible air/fuel issue
  • Tim83
  • Jul 22, 2022
2K
Fox 5.0 Mustang Tech Jun 26, 2023
Tim83
T
C
New here. Was left a 67' Mustang 347. Ready to go down the rabbit hole but don't know where to start.
  • cmille198
  • Jun 29, 2023
2K
1965 - 1973 Classic Mustangs -General/Talk- Jul 12, 2023
AeroCoupe
