Lincoln Mark 7 breaks help!!
  • Thread starter Thread starter jmd2914
  • Start date Start date Feb 15, 2006
J
jmd2914
937
Napa, California
Feb 15, 2006
  • Feb 15, 2006
alright i was driving home and i heard some squeaking coming from my rear break area, i get home and check i and there is alittle bit of play in the rear drivers side caliper. however there is no play in the passenger side, the only differance i can see is that the rubber insert that goes around the caliper pin is worn to pretty much nothing on the drivers side and the passenger side is fine, could this be causing my problem??
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Feb 15, 2006
  • Feb 15, 2006
Check the pins. Make sure 1 didn't back out on you. You'll need an allen wrench to remove the pins to inspect the calipers.
troyGT03
278
too close to memphis,tn
Feb 15, 2006
  • Feb 15, 2006
if the pins hold or stick the caliper then the piston in the caliper is put into a bind. then it rides in that bind until the piston gets scored enough for you to notice a problem.... replace the caliper. i have the same calipers on my saleen and on my svo i sold. the reman front calipers are cheap from the parts stores.
troyGT03
278
Feb 15, 2006
  • Feb 15, 2006
buy a brake hardware kit w/ the caliper and you have the prob fixed.
J
jmd2914
937
Napa, California
Feb 15, 2006
  • Feb 15, 2006
so theres no way to fix it using the caliper i have now? and how much should the rear divers side caliper cost me?
Mavrick
2,264
Collingwood, ON
Feb 15, 2006
  • Feb 15, 2006
Reman rear Mark VII calipers were pretty expensive for me.. $260 Canadian for the pair, loaded.
J
jmd2914
937
Napa, California
Feb 16, 2006
  • Feb 16, 2006
damn, do they only sell them in sets?
Mavrick
2,264
Collingwood, ON
Feb 16, 2006
  • Feb 16, 2006
No, you can get left and right calipers seperatly.
I'm going to assume that you can find them cheaper, being in the US. Canadian parts are always more expensive.
J
jmd2914
937
Napa, California
Feb 16, 2006
  • Feb 16, 2006
Hmm, ok. So just check local autoparts stores and see who carries them? and another dumb question being all ive done with brakes is swap my pads. how do i change the caliper?
Zero_chance
1,244
Maricopa, AZ
Feb 16, 2006
#10
  • Feb 16, 2006
  • #10
Remove the brake line, dont lose the round line gaskets, remove the caliper and install the new one, attach the line and bleed the brakes.
352Ford2
393
Seattle,WA
Feb 16, 2006
#11
  • Feb 16, 2006
  • #11
Before you start throwing parts at it, take it appart and figure out whats wrong first, if its just the pin there is no need to spend a 100 bucks replancing everything just go to the junkyard and get one for a buck (or free if you want to stick it into your pocket) or get the hardware kit from Napa
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Feb 16, 2006
#12
  • Feb 16, 2006
  • #12
My thoughts exactly.
Pull the wheel off and take off the caliper and have a look first.
J
jmd2914
937
Napa, California
Feb 17, 2006
#13
  • Feb 17, 2006
  • #13
well i replaced the caliper, and the play was almost completely eliminated so i think it helped. thanks for the help guys
Mavrick
2,264
Collingwood, ON
Feb 17, 2006
#14
  • Feb 17, 2006
  • #14
You should always REPLACE the crush washers, never re-use them. I assume new ones came with your new caliper?
J
jmd2914
937
Napa, California
Feb 17, 2006
#15
  • Feb 17, 2006
  • #15
crush washers? i got new brass washers that went on the brake line if thats what youre talkin about
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
R
1994 GT 5.0L crank no start
  • Red1994MustangGT
  • Apr 15, 2025
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Aug 19, 2025
Kurt_MO
K
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
J
Rear caliper will NOT go back on! SOMEONE PLEASE HELP
  • Julaneinn
  • Oct 28, 2023
1996 - 2004 SN95 Mustang -General/Talk- Oct 28, 2023
