Lincoln Mark VII (V7) ?
BlackLX5.0
76
I found a lincoln mark v7 and I was wondering if the AOD with the original driveshaft from it would work in my 91 5.0 Lx? The one I have in my mustang now is out of a 89 Lincoln Town Car and my driveshaft wouldnt work. So I had to find a smaller driveshaft and its a little to short.
Thanks :SNSign:
So the mustang transmissions are the only ones that will be the right length for the original driveshaft to work, or is there any other cars that their transmissions will work?
Thanks :SNSign:
The long AODs were in Town Cars, Mark VII's, Crown Vics
and some pickups/vans.
Most other ones will fit, but you do NOT want a V6 AOD.
They've got fewer clutch discs in a couple of the clutch packs.
Check out the transmission dimension chart on the tci
trans website, they give the "regular" AOD dimensions
like for your Mustang.
Basically, the "long" ones just have a longer output
shaft and tailshaft housing. They're 1" longer overall.
If push comes to shove, you can put your Mustang
output shaft & housing on the Mark VII trans, but the
guts have to come out of the trans to do it.
If you don't want to do a rebuild/refresh or any upgrades,
that gets kind of involved unless you're used to working
on AODs. Would probly be cheaper to have your original
Stang driveshaft shortened than hiring someone to do
that swap. Should be the same yoke.
The Linc shafts had a heavy balance weight on the yoke
that I don't think the Stangs had cuz of the shorter shaft
and slightly different angle that made it unnecessary.
For info on how to upgrade AOD's from mild to wild,
and detailed info on parts interchange between AODs,
AOD/Es and 4R70W's, go to www.lincolnsonline.com,
look in the tech section under transmissions.
