line lock need help
  • Thread starter Thread starter surfsup
  • Start date Start date Jun 1, 2008
surfsup
  • Jun 1, 2008
I have a 92 2.3 lx that I did the motor conversion on, the brake system is the 2.3
I bought a B&M line lock but not sure how to install it, my master cylinder has the left front line hooked to the bottom of the master, the other lines all go to the brake distribution box, so I don’t really no how the front brakes work, normally all lines run to the distribution valve and then to the wheels. How is the left run wheel being controlled for the right pressure? Any way, because of this set up I’m not sure where the line lock should be installed, any help would be great
also how the hell do you use that metal tube that b&m put in the box, it's supose the measure the brake line or fitting for the correct size line
__________________
trbkrb
1,976
Houston, TX
Jun 2, 2008
  • Jun 2, 2008
Welcome to the screwed up work on Fox Mustang brakes! Basically, you need to block off the third port on the MC and tee the two front lines into the line lock. Here is a schematic a friend did on his installs. Hope this helps!
surfsup
  • Jun 2, 2008
line lock
thanks for the info,
G
2019 GT Line lock
  • gray owl
  • Jul 18, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Jul 25, 2026
gray owl
G
Hammer shifter problems
  • 387lx
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2026
General karthief
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
A
SN95 Hydroboost in a Fox | Brake lines
  • arc_jpiv
  • Sep 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 14, 2026
2000xp8
