I'm usually preaty good at wireing schamatic's,but for some reason this just isnt clicking today? Ok heres what i'm doing.I bought a fan controler from hayden. In the instructions it says to connect the yellow wire (ignition signal) to a positive 12volt connection that is controlled by ignition.To allow fan/fans to operate with the ignition off,connect yellow wire to a constant live (hot) lead.So is it me or is that not correct? To me it sounds like i need to connect it to a positive hot always,but then to a ignition source when the keys on? I'm confussed on this one?BUT can i connect it to the trigger (small) wire on the starter relay (thing on the fender)? Also another thing i got a dual speed dual fan set up,i'm only wireing this up to use the high speed speed. So i took the orange fused wire and connected it to the high speed side of the fans.In the instructions it says to connect the orange fused wire to the fan power wire.Ground the remaining fan motor wire. Do they mean to ground the black fan wire?Also there is a blue wire off the hayden kit. It says to do the following.Blue wire (power ourtput) used for dual fan installation.Attach the blue wire to a fuse holder and then to the second fan power wire.So since i'm ONLY using the high speed on the fans the way i have it wired (to the orange power output) i dont need to worry about the other (this blue one) correct?I'm 99% sure on my wireing so far it's just for some reason that yellow wire off the hayden kit (ignition signal) has me a little confused?peace
john
john
