LMR Youtube Channel
GTD vs GT500 Head to Head at Circuit of Americas | Track Day
View: https://www.youtube.com/watch?v=RMNh6DfQAns
In this video, the LMR crew is out for a track day at Circuit of the Americas hosted by Edge Addicts. The two cars featured are a 2026 Mustang GTD and 2020 Shelby GT500 with the carbon fiber track package. Until the Dark Horse SC hits the street, comparing the last best Mustang to the GTD is an S550 GT500. Both feature a supercharged 5.2L engine and a host of track-specific add-ons.
*Product Links*
Shop: https://lmr.com/
SVE CFX Wheels: https://lmr.parts/mustang-sve-cfx-wheels-15-21
Garmin Catalyst: https://lmr.parts/GAR-0100234500
*Watch*
2026 Mustang GTD vs 2020 GT500 Lap Battle:
View: https://youtu.be/4W0uTWI4SzY
Mustang GTD Dyno:
View: https://youtu.be/ITiV1AWg63w
2020 CFTP Shelby GT500 Dyno:
View: https://youtu.be/B2KIVoGVveE
*Chapters*
00:00 -
*Social*
YouTube: https://www.youtube.com/user/latemodelrestoration
Facebook: http://www.facebook.com/latemodelresto
Instagram: http://instagram.com/latemodelresto
TikTok: https://www.tiktok.com/@latemodelresto
#lmr #gtdmustang #shelbygt500
Use of this video is subject to the terms as set forth in our LMR Install Video Disclaimer | https://lmr.com/page/lmr-install-video-disclaimer
1994-2004 SN95 & New Edge Mustang: OE-style Battery Cable Kit - How To Install
View: https://www.youtube.com/watch?v=gD-rLeRLnUg
Replace the corroded battery cables in your 1994-2004 Mustang with this high-quality LMR battery cable kit! Your battery cables are vital to operating the charging and starting system of your SN95 or New Edge. We all know that one of the biggest issues with this generation of cars is that the battery cables are integrated into the main harness with no replacements. Your only choice is finding a good second-hand harness, a NOS harness, or cutting up your factory wiring. LMR went about creating a solution-based cable kit that mimics the OE wiring. Excessive corrosion, engine bay heat, and general wear will deteriorate your battery cables. This can cause numerous issues, such as voltage drop, battery drain issues, improper charging, and unsafe operation of your Mustang. LMR's new main battery cable assembly includes positive battery cable, negative battery cable, that utilizes OE-style terminals and correct PCM ground.
LMR is dedicated to providing superior, solution-based products made from the highest quality materials! Each cable features OEM style construction to maintain the factory look. Heavy-duty vinyl rubber sheathing over the wires with a protective convoluted tubing loom protects the cables from engine bay heat and abrasion. Durable factory-style battery terminals are used alongside corrosion-resistant hardware! LMR designed this cable kit to completely replace your original cables by maintaining the factory routing, placement and connection points. LMR has you covered down to the small details, even including extra wire loom, cable clips, and electrical tape to refresh the existing sub-harnesses. A pack of zip ties is also included to aid in harness management.
*Product Links*
94-04 Replacement Battery Cable: https://lmr.parts/LRS-14300TB-K
94-04 Mustang Battery & Starter Parts: https://lmr.parts/94-04-Mustang-Battery-Starter-Components
*Watch*
94-04 Mustang Videos:
View: https://youtube.com/playlist?list=PLMti2eKQ3th_SMVaWhDt8PIAuuwAZBL0I&si=r1yIFvNBJxnlA5CV
LMR Dyno Videos:
View: https://youtube.com/playlist?list=PLMti2eKQ3th9N3EXdgjS8wV0u1RzAv4eM&si=B-MQzg9ji09iZ-QM
*Vehicle Fitment*
Make/Model: Ford SN95 & New Edge Mustang
Year Range: 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004
*Social*
#lmr #newedge #sn95mustang
1996-2004 Mustang: 4V 4.6L Replacement Crossover Tube - How To Install
View: https://www.youtube.com/watch?v=TINFFjA7qGU
Restore the cooling system on your 96-98 Cobra, 99-01 Cobra, or 03-04 Mach 1 with LMR’s coolant crossover tubes! These high-quality reproduction crossover tubes are designed to replace the cracked or leaking factory unit commonly found on these Mustangs. The original OE tube was susceptible to rusting from the inside out due to the lack of an internal protective coating, often leaving owners searching for hard-to-find used parts or costly NOS replacements. LMR’s solution is a durable reproduction crossover tube that features both internal and external corrosion-resistant coatings to help prevent future rust issues. Each tube is manufactured with the correct tubing diameters, factory-style mounting brackets, and proper seals to ensure a hassle-free installation.
Late Model Restoration’s commitment to delivering quality, solution-based products is evident in every detail of this coolant crossover tube. Constructed from durable steel and finished with a satin black E-coat both inside and out, this tube is built to last. Precision-stamped and welded mounting brackets are positioned exactly like the factory unit for an OE-style fit and function. Factory dual sensor ports are retained, along with the original vent port on top of the tube. Preinstalled O-ring seals are included for convenience, as well as a block-off plug for applications where the factory sensor port is not used. Installation is straightforward; simply remove the factory crossover tube, transfer your sensors, and install the new LMR replacement.
*Product Links*
96-98 Cobra Coolant Crossover Tube: https://lmr.parts/LRS-8548B-K
99-01 Cobra & 30-04 Mach 1 Coolant Crossover Tube: https://lmr.parts/LRS-8548A-K
94-04 Mustang Cooling Parts: https://lmr.parts/94-04-Mustang-Engine-Cooling-Heating
*Watch*
LMR Dyno Videos:
*Vehicle Fitment*
Year Ranges & Trim:
- 1996, 1997, 1998 Cobra
- 1999, 2001 Cobra
- 2003, 2004 Mach 1
*Social*
PP1 S550 Mustang Gets Roush MagneRide Lowering Springs & Sway Bars
View: https://www.youtube.com/watch?v=ogTVmF3OEok
When it comes to suspension parts, there’s a lot of stuff to choose from. Lee, one of LMR’s tenured employees opted for Roush suspension components on his Performance Pack 1 S550 Mustang GT. These parts include lowering springs for the Magneride suspension, front and rear adjustable sway bars, and a Magneride calibration to take advantage of new ride height. While we were here, Dark Horse camber plates were fitted to the struts for quick camber adjustment whenever Lee frequents the track.
Landan will walk you through some of the installation steps while providing some highlighted tech notes along the way. After the parts are buttoned up, we hit the street with Lee’s car to provide some feedback on the newly installed parts.
*Product Links*
Rough Magneride Spring & Sway Bar Kit: https://lmr.com/item/RSH-42233M/roush-mustang-magneride-handling-pack-18-23
Roush Magneride Springs: https://lmr.com/item/RSH-422330/roush-mustang-lowering-springs-magneride-18-26-422330
Roush Magneride Sway Bars: https://lmr.com/item/RSH-422340/roush-mustang-front-rear-adjustable-sway-bars-15-25-422340
*Watch*
S550 Mustang Videos:
How To Remove S550 Shocks/Struts/Springs:
View: https://youtu.be/vTMp78FpBv8
How To Remove S550 Sway Bars:
View: https://youtu.be/0v6Iy9JYjyM
*Social*
#lmr #s550mustang #roushperformance
