  • SN95 4.6L Mustang Tech
Locations For Temp Sensors
  • Thread starter Thread starter ONESLO2V
  • Start date Start date May 25, 2016
O
ONESLO2V
12
Pinehurst, NC
May 25, 2016
  • May 25, 2016
While my car is still off the road, I'm going through various different things making sure they're done right before really starting to put miles on it (trans is in the shop...as a start). I have a 1999 Mustang GT. I'm wanting to put 3 gauges in my car... Oil Pressure, AFR, and Water temp. I'm going to use Auto Meter Cobalt electric gauges. I have no idea where in the engine bay to put the sending units for the oil pressure and water temp gauges. Hoping you guys and gals might have some idea as to where. If you have pictures, that'd be really helpful as I'm a visual person...
Thank you!
Ogre
120
NC
May 30, 2016
  • May 30, 2016
Temp sending unit can be put in the block drain plug (just above oil pan in block in cylinder #8 area).
Oil sending unit can be put in the plugged hole beneath where your oil pressure sending unit is (unit under the oil filter area).
Ogre
120
NC
May 30, 2016
  • May 30, 2016
Coolant drain plug:
http://www.svtperformance.com/forum...t-plug-for-my-temp-sensor-I-m-about-to-scream!!!
Oil pressure unit pics here:
http://forums.tccoa.com/37-work-progress/75977-how-convert-your-oil-pressure-gauge-pics.html
O
ONESLO2V
12
Pinehurst, NC
May 31, 2016
  • May 31, 2016
Shortly after I had posted this, I found an article talking about the drain plug. I believe for the oil pressure, I'm going to pick up one of those oil filter plates that allow you to tap in a couple of devices right at the filter. Is that location an accurate location for oil pressure?
Progress Thread Sask84gt's 84 GT - Questions and Progress Thread
  • Sask84gt
  • Oct 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
Sask84gt
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
G
2016 GT, Cold Air/Tune Trouble (overheating) . Advice/Help Please!
  • GLStang
  • Sep 6, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Sep 6, 2025
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sunday at 4:40 PM
manicmechanic007
