  • 2015 - 2023 (S550) Mustang -General/Talk
  • 2015 - 2023 Specific Tech
Longevity Mods?
  • Thread starter Thread starter Aznpersuasion
  • Start date Start date Sep 17, 2015
A
Aznpersuasion
9
  • Sep 17, 2015
Is there a sticky (or even enough mods) for longevity mods for our cars (engine/drivetrain). My 2014 chevy 1500 it was recommended to install an air/oil separator due do it being DI and the intake valves get super dirty by 50k requiring disassembly to clean them. Something like that. Thanks.
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,254
204
South Jersey
Sep 18, 2015
  • Sep 18, 2015
If you have some information that could lend itself to lengthening the life of these cars, I would be glad to make that a Sticky
With that being said, an air/oil separator is never a bad idea. I've seen first hand how much oil the UPR catch cans have pulled from a brand new motor and am down right impressed! I'll be installing a catch can on my S550 over the winter with a few other upgrades that are planned. For the most part, the coyote motors have been proven to hold up to the abuse (exceptions apply )
Admin Dude
Jan 4, 1985
43,351
21,546
234
Box behind Walmart
Sep 18, 2015
  • Sep 18, 2015
I've had this thought several times in reference to catch-cans:
Why not install a one-way check valve in the bottom of the can that allows oil to return to the pan once the motor is shut off?
There would be virtually zero down-side for anyone who changes oil at regular intervals.
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,254
204
South Jersey
Sep 20, 2015
  • Sep 20, 2015
This is a pretty solid idea, implementing it in a plug and play fashion would be the difficult part. The only down side I could possibly see is pulling contamination into the intake system if thst drain check valve failed? Just brainstorming here
Admin Dude
Jan 4, 1985
43,351
21,546
234
Box behind Walmart
Sep 20, 2015
  • Sep 20, 2015
The method would be simple. Vac would close a one-way check valve at the bottom of the can to keep the can from sucking oil from the oil pan when the motor is running. When the motor stops, gravity open the check valve and the oil slowly drains back into the pan.
The only mod an existing catch can would need is the one-way valve and a drain line going into the oil pan.
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,254
204
South Jersey
Sep 21, 2015
  • Sep 21, 2015
I'm thinking the difficulty would be the modification to the oil pan, not everyone is keen on the idea of putting a tap in there (I may be one of the few exceptions to that?). To play devils advocate, what happens when/if the check valve fails? To this point, I had to change a passing check valve on my IMRC's just yesterday. This particular check valve was a Ford part (re-purposed from 03/04 cobra) to keep the boost pressure off of the IMRC's. I got a CEL that had me look into this and found a bad check valve to be the issue. I suppose that if the drain was above the oil level even a bad check valve would only add to the vacuum in the crank case? Just thinking out loud here
Admin Dude
Jan 4, 1985
43,351
21,546
234
Box behind Walmart
Sep 21, 2015
  • Sep 21, 2015
If the check valve fails and the drain line is above the oil foll level (which it should be) then you have one more small avenue of crank case vent.
Blandnuts
I don't swallow; I only swoosh
1,172
124
124
FloorDuh
Sep 23, 2015
  • Sep 23, 2015
The oil is contaminated. This guy actually had his tested.
Why having a catch can is best!!! - Lightning Forum | LightningRodder.com
Admin Dude
Jan 4, 1985
43,351
21,546
234
Box behind Walmart
Sep 23, 2015
  • Sep 23, 2015
Yes, yes, I understand this argument. Again, we're talking about changing oil at regular intervals (often it's changed even more often than necessary... damned gear heads). Oil is DESIGNED to take on contaminated particulates. Talking about water content in oil that doesn't ever reach operating temp is a bit pointless. Leave oil to collect anywhere that it has access to ambient air, it's going to pick up water. This is also a function of motor oil.
His test results are not a convincing argument for a catch can. Take those same results and dilute them over 5+ quarts of oil.
Blandnuts
1,172
124
124
FloorDuh
Sep 24, 2015
#10
  • Sep 24, 2015
  • #10
To each their own. The info is there to read and determine if pouring the oil back in and diluting it is better than adding fresh oil.
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,254
204
South Jersey
Sep 24, 2015
#11
  • Sep 24, 2015
  • #11
If 2 or 3 ounces of water doesn't come out of my oil pan before the first drip of oil than I know something is wrong.... Oh wait we are talking about the alcohol motor in my 84'....
Any engine temp under 180 degrees will condense water no different than any boiler system, most cars will condense water while they are warming up (except electric ones lol) so I agree that water content in the oil is a moot point save the example of my racing hoagie
Mattstang04
1,152
144
104
St. Louis, MO
Oct 3, 2015
#12
  • Oct 3, 2015
  • #12
When I run on alcohol, I get many ounces of water coming out of my racing hoagie....
This joke is weak.....I need a drink.
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,254
204
South Jersey
Oct 3, 2015
#13
  • Oct 3, 2015
  • #13
Keep drinking lol just keep drinking
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
A
Fox Planning on building my foxbody and was wondering if I can get any tips or anything to watch out for!
  • Angelq1028
  • Oct 31, 2024
  • 2 3 4
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 29, 2025
Robman8028
R
H
New kid on the block
  • HydraX
  • Mar 22, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2025
HydraX
H
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
