I am just trying to figure out whether I am understanding some of these numbers correctly. This is something it says:
Valve timing at .006:
open/close
int 27 BTDC 63 ABDC
exh 74 BBDC 22 ATDC
The cam has 270/276 degrees of duration to it, and it has .544" lift. So doing some simple algebra, I came to the conclusion that at TDC, the intake valve will be opened .1088" and the exhaust will be opened .0867". Simple math really, since the intake valve is opened for 27 degrees before TDC, and it reaches peak lift halfway through its total duration(270/2=135), you would do 27/135 then multiply that by .544. Same type of equation for the exhaust.
Now for the questions. Can I assume that the way I did it, or does it open and close at a different rate, not uniformly? If it isn't uniform trhoughout, there is no way for me to find that out is there?
Also, if I would happen to be right, is there a way to tell how far the valve would be from the piston? Say the valve were not moving, does anyone know how close the piston gets to the valve at TDC, or at different times throughout its stroke?
I am still going to use clay to check my piston/valve clearance, but I want to get some sort of idea now(stock valves/pistons). I am trying to figure out if I can run 1.7's or not.
Also, it says the specs are for the cam installed at 108 intake center line. What does that mean? That is the only thing I really have no clue about.
Thanks for the help, I appreciate it. Sorry it's so long.
Chris
open/close
int 27 BTDC 63 ABDC
exh 74 BBDC 22 ATDC
Chris
