loss of power at full acceleration??
a1yola
My car has been experiencing this problem on and off.
Basically, when I am in 1st or 2nd gear and I floor the gas pedal, it sometimes feels like it falls flat on its face...but then begins to pull hard right after. It only occurs when the RPM's are below 3K. If I am above 3K RPM and then floor the pedal, it seems fine and pulls hard. Someone told me that it could be due to a faulty MAF sensor, but I'm not sure. Any ideas??
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
I've ran a code test and it said something about the IAC valve. I replaced it, and the code is still there. Not sure why though:( Can the IAC be causing this problem??
i have the same prob i just installed a set of gt40p heads on mine and when you stomp the gas it kinda feels like a turbo car it has some lag. I have been messin with the timing and it seems to change it. Have you installed anything lately or messed with the timing.
what year is your vehicle? IIRC, there is not (at least for 86-93) a code for IAC. what code did you get?
Check the TPS, make sure it climbs in voltage consistantly as the throttle increases. Should be from .9 at idle and about mid 4's at WOT in voltage from the signal wire. If not that, check fuel pressure and MAF.
my car is a 89. I forget what code came up, but I do remember it saying something about the IAC. I am going to clean my MAF tomorrow and see what it does. No, I havent changed my timing or fuel pressure recently either.
HISSIN50 said:
I believe that 12 and 13 would relate to the IAC.
yep, i forgot about those.
12 and 13 are for idle. sometimes caused by a clogged or faulty IAC, most of the time the idle is not in the proper range. since you've replaced the IAC already, you might want to make sure your idle is set properly. also make sure your throttlebody plate moves freely and is not sticking at all.
